Use this guide to replace the WWAN card in your Lenovo ThinkPad T480s laptop.
The WWAN (wireless wide area network) card allows you to connect to the internet without relying on a local Wi-Fi connection. If your computer has a WWAN card installed and you are having trouble using the internet without Wi-Fi, you may have a faulty WWAN card or antenna.
If you are having trouble accessing a local Wi-Fi connection, you may need to troubleshoot or replace the Wi-Fi card or WLAN antennas.
Before attempting a replacement, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
Loosen the six captive screws with a Phillips #1 screwdriver.
Remove the bottom cover with an opening tool.
Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
Flip the cardboard cover off of the WWAN card.
Using the spudger, release the coaxial antenna wires from the WWAN card.
Use a Phillips #1 screwdriver to remove one 2.8mm screw.
Slide the WWAN card out from the slot.
You can also install a secondary SSD into the WWAN slot, but it must fit these requirements:
- SSD size: M.2 2242,
- It must be M+B keyed, and
    - (Hypothetically, only the SSD being B keyed is needed, but I haven't seen any NVMe SSDs that are only B-keyed.)
- It must be single-sided, with respect to surface-mount components.
Information came from this video for the ThinkPad T480, but the ThinkPad T480s is similar enough to the ThinkPad T480 for this to work.
