Lenovo ThinkPad T480s Fan Assembly Replacement
  1. Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disable the battery, power down the device, and unplug the power adapter from your device before proceeding/beginning the guide.
    • Loosen the six captive screws with a Phillips #1 screwdriver.
    Somehow I find the screws for the T480s bottom cover to be slightly more prone to stripping, compared to the ThinkPad T480 and X1 Carbon Gen 6. However, the #1 Phillips screws on the T480s have drives that are cut in a way that also let you use a #3 flathead.
    Tai Lam - crwdns2934203:0crwdne2934203:0
  2. Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the bottom cover with an opening tool.
    • Start from the top edge near the hinge and work your way along the edge until all of the clips are unsnapped.
  3. Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom cover off.
  4. Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement, Fan Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to disconnect the fan cable from the motherboard.
  5. Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the four captive screws attaching the fan assembly to the motherboard.
    • Do not attempt to remove the captive screws, as forcing them out may strip or damage them.
    I just checked on my model of the T480s, and I don't believe the vertical pair of screw holes on the left are actually part of the fan/heatsink assembly. I know I bought my unit used, but these screw holes also came empty. Despite having visible threading that can accept a M2x2.7 screw (I don't know if this is the actual size of the screw), only the 4 screws around the CPU are the screws physically securing the combined fan/heatsink assembly.
    I found the screw on position 3, around the CPU heatsink, to be stubborn enough that I stripped the screw with a Phillips #1 drive bit. If you find yourself in this predicament, don't worry - in my case, I discovered that using a flathead #2 drive bit helped me get out of this bad situation (for long enough to loosen and tighten this CPU heatshink screw, at least until I obtain a replacement M2x2.5 size screw).
  6. Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T480s Fan Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan assembly from the system and remove it.
    • Follow our thermal paste application guide before you replace the fan assembly and are ready to reassemble your device.
    Is it necessary to replace the thermal paste on the CPU?
    gordonzaft - crwdns2934203:0crwdne2934203:0
    Hi gordonzaft, it's a good idea to reapply thermal paste after removing a heatsink or CPU for a repair. You may already know how to apply thermal paste, but if you'd like a refresher or some general instruction, check out the How to Apply Thermal Paste guide. Thanks!
    Sarah Westberg -
Sarah Westberg
crwdns2935283:003/11/19crwdne2935283:0
32 112 crwdns2915208:0crwdne2915208:0
crwdns2935297:071crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 667crwdne2935297:0
Thank you, @hansrteterra! I'm glad you found it helpful.
Sarah Westberg -
crwdns2936753:07crwdne2936753:0 40
crwdns2936753:030crwdne2936753:0 180
crwdns2942667:0crwdne2942667:0 5,024
