If the coin cell or CMOS battery of your Lenovo ThinkPad T480 begins to fail, follow this guide to replace it.
The CMOS or coin cell battery provides power to the CMOS (complementary metal oxide semiconductor) chip. Some signs of CMOS battery failure include: settings in the computer setup changing, the clock resetting, “Booting Error” messages, the laptop running slowly, or the laptop shutting down.
Prior to beginning this repair, be sure to disable the internal battery, shut down the laptop, and disconnect from the external power source.
Flip the laptop over so the bottom of the device is showing.
Using your fingers, slide the lock on each side of the battery to the unlocked position.
Remove the battery from the slot.
Using the Phillips #1 screwdriver, loosen the six captive screws.
Insert the blue plastic opening tool into the space between the lower case and the chassis.
Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
Remove the back case.
I found a tough spudger (or even better a plectrum) is best here as the clips, although easy to separate, hold the case firmly leaving a tight gap which a soft spudger may fail to enter.
Hi Benjamin, thanks for the tip!
You also have to pry the near the battery. I experienced that you can't pry the front side.
I used a credit card to pry the clips loose, it worked great. Added 2nd RAM stick easily.
Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
Lift the battery straight out of its recess and remove it.
DO NOT wedge out the battery - T480 has two screws that hold down a plastic battery tray which easily lifts out after the two frame screws are removed. Wedging out will ruin the battery and could damage the cell and cause a fire.
The guide says to remove those two screws. They are "lifting" with the wedge. Probably more of a way to promote their tools than out of necessity, but idk
You lift the internal battery first from the top, and then the bottom.
This is because there are 2 "clips" on the bottom that the battery uses to slide into the chassis.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the black nylon spudger, pry the coin cell battery off of the motherboard.
good documentation easy to follow top woman
EN: NOTE: The built-in battery needs to be disabled first! This can be done in the BIOS.
DE: ANMERKUNG: Die eingebaute Batterie muss zuerst deaktiviert werden! Dies kann im BIOS getan werden.
Thomas - crwdns2934203:0crwdne2934203:0
