If your laptop is not charging correctly you can replace the power jack using this guide.
Flip your laptop over so the bottom is facing up.
Remove the memory panel by removing two black 5mm screws using the Phillips #0.
Remove the memory panel.
Remove the two 5mm screw using the Phillips #0 screwdriver.
Flip the laptop back over and open it.
Gently push down on the keyboard and slide it towards the screen. This will pop the bottom of the keyboard out of the casing.
Using the metal spudger, lift and slide out the keyboard.
Remove the orange cable by lifting up on the tab on the end of the ribbon connection.
Remove the additional thirteen 5 mm screws with your Phillips #0 screwdriver.
Remove the two 2.5 X 5 mm screws from the back of your laptop.
Remove the 3 mm screw from the back of the laptop using the same screwdriver.
Disconnect the black and gray antenna cable connectors in the memory panel on the back of the laptop.
Remove any plastic wraps on the blue, white, and tan wires.
Flip the laptop back over and pull all the wires from the previous step through to the top side.
Remove the three 5mm screws holding the palm rest casing in place using the Phillips #0.
Unplug the red, white, and blue bunch of wires.
Lift up the black retaining flap holding the purple ribbon cable in place, and carefully slide out the ribbon.
Remove the top casing by lifting up and sliding out.
Unplug the two black cables that connect the screen to the motherboard.
Flip your laptop so the back-side is facing towards you.
Remove any black stickers covering the screws using the nylon or metal spudger.
Remove the two 7mm screws using the Phillips #0 screwdriver.
Remove the LCD screen unit by holding the sides and lifting it upwards.
Remove the 3mm screw next to the power jack using the Phillips #0.
what is the name of the power jack? Is there a place where i can buy the power jack on the card so i dont have to soder?
Lift the power jack and slide to the right to remove.
crwdns2935229:015crwdne2935229:0
This is not the Lenovo Thinkpad T420. You can Tell by the RAM memory Slot Cover and the Position the RAM is put into its slot. the T420 RAM is Vertical Compared with being Horizontal in this Picture. that includes the cover also. Then the Battery Slot is a Dead Giveaway clue. The T420 Battery slot is in the middle. and this Picture has the battery slot to bthe left. Sorry Not Even Close. None of the screws he removes are on the T420. so this is Completely Useless. Thanks
This is T420s!
it is not easy to replace a power jack for Lenovo ThinkPad T420S because it requires soldering job and people might burn the board while doing the job, you are replacing a power jack board, just disassemble and assemble the laptop, here is a seller for Lenovo ThinkPad T420S power jack board: http://www.dcincable.com/04w1699-04w3997...
Thanks for the writeup. How can I test if power is getting out of the actual jack and to the end of the powerjack module? Just wondering across what do I put the MMeter? Thanks. Matt
https://www.youtube.com/watch?v=rGMFSdFW... This is how you test adapter, this guy also shows you in another video how to test your jack.
Seth Carnett (Mr2ndopinion) - crwdns2934203:0crwdne2934203:0
This guide is very well done. Thank you. Moving slowly and carefully, it took me almost two hours. So, I’d say the 30 minute time estimate is more for a seasoned laptop repair pro!
