Use this guide to replace the lower case on your Lenovo ThinkPad T15 Gen 2.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Use a Phillips #1 screwdriver to loosen the eight captive screws securing the lower case.
Insert an opening pick between the lower case and the chassis on the front right edge.
Angle the pick down at about 30 degrees.
Slide the pick along the front edge to release the clips securing the lower case.
Insert an opening tool between the lower case and the chassis, just to the right of the USB port on the left edge.
Pry the opening case up to release the clip next to the USB port.
Insert an opening pick on the left edge above the USB port. Slide the pick all the way up to the ethernet port to release the clips.
Insert an opening pick on the right edge near the corner.
Slide the pick along the right edge all the way to the HDMI port to release the rest of the clips.
Lift the lower case from the chassis and remove it.
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad T Series answers community for help.
Pls make sure to eject the Sim tray before lifting the cover, otherwise you'll bend it
