Lenovo ThinkPad T14 Gen 3 Screen Replacement
  1. Lenovo ThinkPad T14 Gen 3 Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS #1 screwdriver to loosen the seven screws from the back panel.
    • Turn each screw counter-clockwise at least 3 turns and move on to the next step.
    • Screws will not come out of the panel, so you don't have to worry about losing them.
    • Place the end of a spudger or opening tool into the seam to gently separate the back cover from the rest of the device.
    • Slide the opening tool around the perimeter of the device to release the clips that hold the back panel to the device.
    • Remove the back panel.
  2. Lenovo ThinkPad T14 Gen 3 Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
    • There is a risk to your laptop if the battery is not discharged properly.
  3. Lenovo ThinkPad T14 Gen 3 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the battery from the battery connector and remove it.
  4. Lenovo ThinkPad T14 Gen 3 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to gently pry the edges of the bezel, carefully removing it. Then, gently remove it and set it aside.
    • Be careful not to damage the bezel as it will be reused.
    • Flip the screen over to reveal the display connector.
  5. Lenovo ThinkPad T14 Gen 3 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With a spudger, disconnect the screen from the connector.
    • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Lift screen up and away from device to remove fully
    • There are 2 lines of tape on either the back of the LCD or on the case. These strips of tape help secure the LCD to the case. The new tape included with your screen should be applied to the same location, if possible.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abby Adams
crwdns2935283:004/14/25crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-2, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-2, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G2
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 234
crwdns2942667:0crwdne2942667:0 871
