Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement
  1. Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS #1 screwdriver to loosen the seven screws from the back panel.
    • Turn each screw counter-clockwise at least 3 turns and move on to the next step.
    • Screws will not come out of the panel, so you don't have to worry about losing them.
    • Place the end of a spudger or opening tool into the seam to gently separate the back cover from the rest of the device.
    • Slide the opening tool around the perimeter of the device to release the clips that hold the back panel to the device.
    • Remove the back panel.
  2. Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a JIS #1 screwdriver to remove six M2 x 5 mm screws that hold the battery in place.
    • There is a risk to your laptop if the battery is not discharged properly.
  3. Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the battery from the battery connector and remove it.
  4. Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement, Cooling Fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement, Cooling Fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the seven 11 mm screws from the heat sink and fan.
  5. Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the fan connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
  6. Lenovo ThinkPad T14 Gen 3 Cooling Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan and heatsink from the laptop.
    • The heat sink for the CPU can be tough to remove. Use an opening tool to help you pry it from the board.
    • Remove the old thermal paste from the CPU using isopropyl alcohol.
    • Put the alcohol on a cotton swab or paper towel, don't pour directly onto the computer.
    • Apply thermal paste to the top of the CPU. if you need instructions on how to remove and replace thermal paste follow this guide here.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Chris Dalton
crwdns2935283:004/09/25crwdne2935283:0
547 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-2, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-2, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G2
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 87
crwdns2942667:0crwdne2942667:0 140
