Whenever a repair is done to the internals of a device, or for cleaning, the cover will need to be removed. You may also need this guide if the bottom panel is damaged and need to replace it. This guide will help you remove the back panel of your Lenovo Thinkpad T14 Gen 3 to access the internals of the machine.
Before you begin this repair, power off and unplug your laptop.
Use a JIS #1 screwdriver to loosen the seven screws from the back panel.
Turn each screw counter-clockwise at least 3 turns and move on to the next step.
Place the end of a spudger or opening tool into the seam to gently separate the back cover from the rest of the device.
Slide the opening tool around the perimeter of the device to release the clips that hold the back panel to the device.
Remove the back panel.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
