Lenovo ThinkPad P50s RAM Replacement
  1. Lenovo ThinkPad P50s RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over so the bottom is facing you.
  2. Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumb to slide the right lock switch button outward.
  3. Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your thumb slide the left lock switch button outward while sliding the battery out with your other hand.
    • When replacing the battery, make sure that the connectors are aligned properly.
    • You may hear a click when the battery is fully seated and the lock engages.
  4. Lenovo ThinkPad P50s RAM Replacement, Base Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement, Base Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to unscrew the eight 2 mm captive screws.
    • These screws should not be removed entirely; you will be able to take off the base cover once they are loosened.
  5. Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the plastic opening tool, pry up the base cover.
    • Slide the opening tool around the edge of the laptop to release the snap tabs.
    • You may need to use opening picks to hold the tabs apart, as the base is securely attached and tends to snap back into place.
  6. Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the base cover off the laptop.
  7. Lenovo ThinkPad P50s RAM Replacement, RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement, RAM: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50s RAM Replacement, RAM: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your thumbs, press outward on the two white retaining arms to release the RAM stick.
    • Slide the RAM out of the socket at the same angle it was released to avoid bending the connecting pins.
    • When sliding the RAM stick into the socket, carefully align the connecting pins to avoid damaging the connector or the RAM stick. Push down on the RAM until the white arms click into place.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Evan G
crwdns2935283:009/09/24crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 8-3, Watkins Fall 2024 crwdns2935289:0Austin Community College, Team 8-3, Watkins Fall 2024crwdne2935289:0
AUSTINCC-WATKINS-F24S8G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 82
