Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly
  1. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the battery latch to the left to unlock it and remove the battery.
  2. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
  3. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Bottom case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the lower case up and off of the chassis.
  4. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Trackpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly, Trackpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following screws with a Phillips #00 screwdriver:
    • Seven 5.7 mm screws
    • Five 4.3 mm screws
    • Three 12.6 mm screws
  5. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the computer over and open the lid.
    • Insert an opening pick in the seam between the keyboard bezel and chassis.
    • Pry around the entire perimeter until the keyboard assembly fully releases.
  6. Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P50 Keyboard Bezel/Trackpad Assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pivot the keyboard further up until you can see the connectors on the underside of the keyboard
    • Detach the connectors that connect to the trackpad.
    • Most of the time, these connectors will have a lip or a tab along the top that can be used to push the connector out of its socket.
    • To disconnect, use the wide end of a spudger to push on the connector tab to slide it out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Sara Richardson
crwdns2935283:003/21/25crwdne2935283:0
609 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-1, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-1, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G1
crwdns2942667:0crwdne2942667:0 120
