Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement
  1. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Turn off your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Turn off your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Turn off your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
  3. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's left side: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's left side: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's left side: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
    • It can be tricky to get the pick into the seam for the first time. Angle the pick vertically and press down with firm pressure.
    • Pivot the pick down and slide it around the corner to release the clips.
  4. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the left edge to release the clips securing the cover.
  5. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's right side: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's right side: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the base cover's right side: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
  6. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the right edge to release the clips securing the cover.
  7. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the base cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the base cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
  8. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the base cover.
  9. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Loosen the battery screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to loosen the six captive screws securing the battery.
  10. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Remove the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the top edge of the battery and lift to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
  11. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery.
  12. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Model differences: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The fans and heatsink assembly may look slightly different depending on the model. The procedure is nearly identical for both models—any differences will be noted in the relevant steps.
  13. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Disconnect the assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Disconnect the assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Disconnect the assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  14. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  15. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to gently guide the two thinner cables (black and yellow) out of their clips on the edge of the left fan.
    • During reassembly, route the two thinner cables and the thicker screen cable into their clips.
  16. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Detach the heatsink: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to loosen all captive screws securing the heatsink.
    • Depending on the model, your heatsink will have either three or five screws.
    • During reassembly, tighten the heatsink screws in ascending order based on the number stamped next to each screw.
  17. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under the top edge of the heatsink and pry up to separate it.
    • Be very careful not to damage any surface-mounted components on the motherboard.
    • Continue prying up along the top edge to fully separate the heatsink.
  18. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the outer edges of the fans and remove the assembly.
  19. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Thermal paste application: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Thermal paste application: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement, Thermal paste application: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reference our thermal paste guide for cleaning and application during the next two steps.
    • Remove all the old thermal paste and its residue from the motherboard:
    • The CPU and GPU have gray thermal paste on them.
    • Depending on the model, your laptop may only have a CPU.
    • The components around the CPU and GPU have a yellow, viscous thermal compound.
    • If you're reusing the heatsink and fan assembly, remove all the old thermal paste and compound from the corresponding spots on its underside.
    • Don't remove the small blue pads from the top edge.
  20. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply new thermal paste to the CPU and GPU.
    • Apply a viscous thermal compound to the components around the CPU and GPU.
  21. Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo ThinkPad P1 Gen 7 Fans and Heatsink Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're reusing the assembly, you can skip this step.
    • If any of the small blue thermal pads stuck to the top edge of the heatsink, carefully remove and transfer them to their corresponding spots on the motherboard.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
118,956 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,677crwdne2935297:0
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 728
