If you need to replace the Wi-Fi card for your Lenovo IdeaPad Slim 3 Chromebook 14M868, follow this guide.
Place the device on a clean dry workspace with the back Cover facing up.
Remove 10 Phillip screws.
Place space tabs around the edges of the back cover to separate from the device.
Firmly but carefully pry the back cover off.
Locate connector.
Pick up on locking tab.
Pull male connector, gently but firm, away from the female connector.
Battery is located directly below the back cover.
Remove 4 Phillips screws.
Remove 1 Phillip screws.
Disconnect the coaxial cables from the Wi-Fi card.
Gently remove Wi-Fi Card by pulling away from the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
