If you need to replace the motherboard in your Lenovo IdeaPad Slim 3 Chromebook 14M868, follow this guide.
Place the device on a clean dry workspace with the back Cover facing up.
Remove 10 Phillip screws.
Place space tabs around the edges of the back cover to separate from the device.
Firmly but carefully pry the back cover off.
Remove 1 Phillip screws.
Disconnect the coaxial cables from the Wi-Fi card.
Gently remove Wi-Fi Card by pulling away from the motherboard.
Disconnect the four connectors from the motherboard.
Remove three Phillips screws from the I/O bracket.
Remove the I/O bracket.
Remove two screws from the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Where do I get replacment mother borad? And will I loose all my information when I replace this? thanks
