Place the device on a clean dry workspace with the back Cover facing up.
Remove 10 Phillip screws.
Place space tabs around the edges of the back cover to separate from the device.
Firmly but carefully pry the back cover off.
Locate connector.
Pick up on locking tab.
Pull male connector, gently but firm, away from the female connector.
Battery is located directly below the back cover.
Remove 4 Phillips screws.
Remove 1 Phillip screws.
Disconnect the coaxial cables from the Wi-Fi card.
Gently remove Wi-Fi Card by pulling away from the motherboard.
Disconnect the four connectors from the motherboard.
Remove three Phillips screws from the I/O bracket.
Remove the I/O bracket.
Remove two screws from the motherboard.
Remove 8 Phillip screws.
Flip up on the hinges.
Locate harness.
On-clip locking tab.
Unplug the harness.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
