Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement
  1. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
    For the picture displaying the two slide latches maybe demonstrate the direction they need to slide
    Christopher Graveline - crwdns2934203:0crwdne2934203:0
    Which direction should you pull the battery? (e.g., away from the device).
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  3. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
    I think you can remove the caution, since it was removed in the previous step.
    Make sure to write the last sentence as a complete sentence.
  4. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
    Specifying the tool used would be a great addition to this step.
    Vanessa Onyullo - crwdns2934203:0crwdne2934203:0
    I agree, and I also think you want to add action shots here.
  5. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Wi-Fi Network Card: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement, Wi-Fi Network Card: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both antenna wires by pulling upwards gently.
    Consider adding an action shot here. Also, use circles only for screws, and boxes for other elements.
  7. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the #00 Phillips screwdriver, remove one 3mm screw from the network card.
    The 00 screw driver worked better for this step.
    Add screwdriver to the text above, here.
  8. Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad S210 Touch Wi-Fi Network Card Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide Wi-Fi network card away from motherboard and remove gently.
    This is another place where an action shot would help.
Zack Colman
crwdns2935283:007/08/19crwdne2935283:0
906 crwdns2915208:0crwdne2915208:0
Can I swap out the card with another make/model? If I don’t want to use a dongle and my OS doesn’t support the original one.
How do I know which will fit?
neb🇳🇴 - crwdns2934203:0crwdne2934203:0
Many months later:
I replaced the card and booted up. No BIOS, just straight to error message:
"Unauthorized Wireless network card is plugged in. Power off and remove it."
Very sly move, Lenovo!
Now I need special hard- and software tools to modify UEFI!
crwdns2942667:0crwdne2942667:0 415
