Lenovo IdeaPad Flex 5-1570 RAM Replacement
  1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the clips have been disengaged, lift off the back cover.
    You should probably disconnect the battery immediately after opening the laptop. Don’t want to risk damaging your nice hardware.
    Zack Colman - crwdns2934203:0crwdne2934203:0
  4. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two tabs on both sides of the RAM stick apart to release the memory module.
    • The RAM will rise up to rest at an angle to the motherboard.
  6. Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 RAM Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the RAM stick out of its port with respect to the angle at which it rests.
    • Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
Austin Blakely
crwdns2935283:003/11/19crwdne2935283:0
21.593 crwdns2915208:0crwdne2915208:0
crwdns2935297:053crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.909crwdne2935297:0
I've had a Lenovo Flex 5 for a number of years and it has been extremally reliable. I wasn't aware that upgrading anything on this unit was even possible. Thank you for this info, I'll be checking into this more.
John - crwdns2934203:0crwdne2934203:0
Please suggest what DDR4 RAM I should buy to replace it. I have a 16 GB, I want to go 32 or 64.
Maulik Darji - crwdns2934203:0crwdne2934203:0
"Patriot Viper Steel DDR4 32GB 2400MHz CL15 SODIMM Memory Module PVS432G240C5S" works on mine
Finality Video -
Thank you for posting this and especially to the commentor that posted the memory upgrade info. This has been a great laptop and I look for to extending the life of it with this upgrade.
Vee - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 10,616
