Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement
  1. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all the clips have been disengaged, lift off the back cover.
    You should probably disconnect the battery immediately after opening the laptop. Don’t want to risk damaging your nice hardware.
    Zack Colman - crwdns2934203:0crwdne2934203:0
  4. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
    My battery completely discharged and even plugging it in won’t power up my computer. I tried removing and replacing the battery, didn’t work, so I completely removed the battery and plugged it in, thinking that would isolate the battery as the issue, but still it will not power up, so I’m thinking it might not be the battery. Shouldn’t it work plugged in without a battery?
    Any advice?
    Jrjan1@icloud.com - crwdns2934203:0crwdne2934203:0
  6. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Daughterboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, Daughterboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, disconnect the CMOS battery from the daughterboard by pushing it out towards the direction of the CMOS battery.
  8. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #00 screwdriver, remove the single 5 mm screw.
  9. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the iFixit Opening tool, remove the silver piece of tape from the device.
  10. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the daughterboard up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, CMOS Battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 5-1570 CMOS Battery Replacement, CMOS Battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, pry the CMOS battery up and remove it from the device.
Justin Ogihara
crwdns2935283:009/18/17crwdne2935283:0
29,521 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
What is the point of disconnecting and removing the daughter board when you've already disconnected the CMOS battery? It seems like there are unnecessary extra steps added.
The Ward Family - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 110
crwdns2942667:0crwdne2942667:0 10,205
