Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
    I have to know how long the pins are in the clips that hold the hinges in place. I don’t want to destroy my tablet.
    otlerelron - crwdns2934203:0crwdne2934203:0
    Mine had ten tiny little star screws. Not Phillips.
    Justen Hansen - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
    You forgot about the part where you have to remove the two screws holding the trackpad in place...
    Pine Castle Hardware - crwdns2934203:0crwdne2934203:0
Elijah Ellis
crwdns2935283:011/08/18crwdne2935283:0
616 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 crwdns2935289:0UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018crwdne2935289:0
UMASSD-GULBRANDSEN-F18S5G2
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - crwdns2934203:0crwdne2934203:0
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,253
