Lenovo IdeaPad Flex 4-1470 Battery Replacement
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
    I have to know how long the pins are in the clips that hold the hinges in place. I don’t want to destroy my tablet.
    otlerelron - crwdns2934203:0crwdne2934203:0
    Mine had ten tiny little star screws. Not Phillips.
    Justen Hansen - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up and out of the laptop.
crwdns2935229:09crwdne2935229:0
Demario Robinson
crwdns2935283:010/02/17crwdne2935283:0
1,047 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G6, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S1-G6, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S1G6
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - crwdns2934203:0crwdne2934203:0
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 14,218
