This Replacement Guide shows step by step how to replace a battery on a Lenovo IdeaPad 3 Chrome 15IJL6.
Use a Phillips screwdriver to remove the nine 4 mm screws that secure the lower case. hrome 15IJL6
Insert an opening pick into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Use the flat end of a spudger to push the battery connector directly out of its motherboard socket.
Remove the four 4 mm Phillips screws that secure the battery.
Lift the battery up and out of the chassis.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
