Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
Use a Jimmy or your fingernail to pry the back panel off.
Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
Use a Phillips #00 screwdriver to remove the two 3 mm screws that hold the hard drive down in place.
Use a Jimmy to remove the blue and black bracket that surrounds the hard drive.
Pull the hard drive from the bottom to release it from its black port labeled S0712.
