Lenovo IdeaPad 330S Wireless Lan Card Replacement
  1. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device off.
    • Remove the 10 screws as shown in picture.
    • Using a pry tool , remove the bottom case.
  2. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Disconnecting Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing guard shield: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 00# screws.
    • Remove the 2.5 mm screw.
    • Gently pry the shield.
  4. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Wireless Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing the screw (marked in red circle) remove the two antenna cables using the spudger.
    • Remove the screw.
    • The wireless card will lift, remove it.
    • Install the new wireless card.
    Before disconnecting the WLAN I recommend to take a picture in your phone to show where each cable goes.
    Ilia Tocheny - crwdns2934203:0crwdne2934203:0
    can a 330s 15-arr ryzen 5 use this ax200? currently using ac 3165, worried that it will cause bios whitelist issue
    Kaizoku 62 - crwdns2934203:0crwdne2934203:0
    You could try to buy it from amazon usually whitelist issue is for Laptop meant for business.
    Ilia Tocheny -
Ilia Tocheny
crwdns2935283:004/30/19crwdne2935283:0
1 667 crwdns2915208:0crwdne2915208:0
So my laptop sometimes has no bluetooth, or wifi, or both. A quick reboot fixes it, but idk if the module is actually faulty. I've opened it before, and don't want to buy a replacement chip if this one is just seated poorly. Is there a good way to check. Thanks
Calvin Mills - crwdns2934203:0crwdne2934203:0
Using the correct tools try to disconnect the cables from the socket and reseat them in the socket make just do as the guide but without removing the WLAN card
Ilia Tocheny -
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 3,887
