Lenovo IdeaPad 310-15IKB Motherboard Replacement
  1. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the lower case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over with the hinge facing away from you.
    • Use a Phillips screwdriver to remove the twelve 6.5 mm screws that secure the lower case and the right panel.
    • It's not necessary to remove the lower left panel unless you intend to replace the HDD.
  2. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the right panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the right panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the right panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the notch on the upper left corner of the right panel.
    • Pry the panel up to release the retaining clips that secure the panel.
    • Remove the panel.
  3. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 6.6 mm screws that secure the motherboard to the lower case.
  4. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the fan cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the fan cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingernails to lift the fan cable connector directly up and out of its motherboard socket.
  5. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the ZIF connectors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the ZIF connectors: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the ZIF connectors: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to flip up the ZIF locking flaps on the keyboard and trackpad connectors.
  6. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the keyboard ribbon cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the keyboard ribbon cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the keyboard ribbon cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt tweezers to pull the keyboard ribbon cable directly out of its socket.
  7. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the trackpad ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the trackpad ribbon cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt tweezers to pull the trackpad ribbon cable directly out of its port.
    • Grip and pull the blue pull tab, not the entire ribbon cable.
  8. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the wireless card cables: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the wireless card cables: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the wireless card cables: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed tip of a spudger to gently pry up and disconnect the two antenna cables from the wireless card.
  9. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Open the laptop lid: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Open the laptop lid: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open the lid.
  10. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the left edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the left edge: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the left edge: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The keyboard assembly is secured to the lower case by plastic retaining clips. You'll hear and feel them release as you work.
    • Insert the tip of an opening pick into the seam between the top left corner of the lower case and keyboard assembly.
    • Slide the opening pick down to the bottom left corner to release the clips.
  11. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the front edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the front edge: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the front edge: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick into the seam between the lower left side of the palm rest and the lower case.
    • Slide the opening pick to the right to release the clips that secure the front edge.
  12. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the right edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the right edge: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unclip the right edge: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick into the bottom right seam between the chassis and keyboard assembly.
    • Slide the pick toward the top right corner to release the remaining retaining clips.
  13. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the keyboard assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the keyboard assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the keyboard assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard assembly off of the chassis.
  14. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use two opening tools or your fingernails to gently "walk" the battery connector directly out of its motherboard socket.
  15. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unfasten the motherboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 3.3 mm screws that secure the motherboard to the lower case.
  16. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the display cable ZIF connector: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the display cable ZIF connector: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to flip up the ZIF locking flap that secures the display cable.
  17. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the display cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the display cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt tweezers to pull the display cable directly out of its motherboard socket.
  18. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unseat the display cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unseat the display cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Unseat the display cable: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt tweezers to lift the display cable vertically to unseat it from the motherboard.
    • The display cable is attached to the motherboard with a mild adhesive. Lift gently to avoid damaging the cable.
  19. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the speaker cable: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the speaker cable: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the speaker cable: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger or your fingernails to gently "walk" the speaker cable directly out of its motherboard socket.
  20. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the HDD and I/O board ribbon cables: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the HDD and I/O board ribbon cables: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Release the HDD and I/O board ribbon cables: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to flip up each of the two ZIF locking flaps that secure the HDD and I/O board ribbon cables to the motherboard.
  21. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the HDD and I/O board ribbon cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the HDD and I/O board ribbon cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the HDD and I/O board ribbon cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt tweezers to disconnect the the HDD and I/O board ribbon cables from their motherboard ports.
    • Grip and pull the blue pull tabs, not the entire ribbon cable.
  22. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the optical drive ribbon cable: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the optical drive ribbon cable: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Disconnect the optical drive ribbon cable: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to flip up the ZIF locking flap that secures the optical drive ribbon cable.
    • Use blunt tweezers to gently pull the optical drive ribbon cable directly out of its motherboard port.
  23. Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the motherboard: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the motherboard: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Motherboard Replacement, Remove the motherboard: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly lift the right side of the motherboard.
    • Slide the motherboard a few millimeters to the right to unseat the ports from the lower case.
    • Grasp both sides of the motherboard and lift it up and out.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
Connor
crwdns2935283:003/29/22crwdne2935283:0
15,231 crwdns2915208:0crwdne2915208:0
crwdns2935297:074crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,813crwdne2935297:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 981
