Lenovo IdeaPad 310-15IKB Disassembly
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Lenovo IdeaPad 310-15IKB Disassembly, Unfasten the lower case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unfasten the lower case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over with the hinge facing away from you.
    • Use a Phillips screwdriver to remove the twelve 6.5 mm screws that secure the lower case and the right panel.
    • It's not necessary to remove the lower left panel unless you intend to replace the HDD.
  2. Lenovo IdeaPad 310-15IKB Disassembly, Remove the right panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Remove the right panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Remove the right panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger into the notch on the upper left corner of the right panel.
    • Pry the panel up to release the retaining clips that secure the panel.
    • Remove the panel.
  3. Lenovo IdeaPad 310-15IKB Disassembly, Unfasten the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three 6.6 mm screws that secure the motherboard to the lower case.
  4. Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the fan cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the fan cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingernails to lift the fan cable connector directly up and out of its motherboard socket.
  5. Lenovo IdeaPad 310-15IKB Disassembly, Release the ZIF connectors: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Release the ZIF connectors: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Release the ZIF connectors: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or a fingernail to flip up the ZIF locking flaps on the keyboard and trackpad connectors.
  6. Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the keyboard ribbon cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the keyboard ribbon cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the keyboard ribbon cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt tweezers to pull the keyboard ribbon cable directly out of its socket.
  7. Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the trackpad ribbon cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the trackpad ribbon cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt tweezers to pull the trackpad ribbon cable directly out of its port.
    • Grip and pull the blue pull tab, not the entire ribbon cable.
  8. Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the wireless card cables: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the wireless card cables: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Disconnect the wireless card cables: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed tip of a spudger to gently pry up and disconnect the two antenna cables from the wireless card.
  9. Lenovo IdeaPad 310-15IKB Disassembly, Open the laptop lid: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Open the laptop lid: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open the lid.
  10. Lenovo IdeaPad 310-15IKB Disassembly, Unclip the left edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unclip the left edge: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unclip the left edge: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The keyboard assembly is secured to the lower case by plastic retaining clips. You'll hear and feel them release as you work.
    • Insert the tip of an opening pick into the seam between the top left corner of the lower case and keyboard assembly.
    • Slide the opening pick down to the bottom left corner to release the clips.
  11. Lenovo IdeaPad 310-15IKB Disassembly, Unclip the front edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unclip the front edge: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unclip the front edge: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick into the seam between the lower left side of the palm rest and the lower case.
    • Slide the opening pick to the right to release the clips that secure the front edge.
  12. Lenovo IdeaPad 310-15IKB Disassembly, Unclip the right edge: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unclip the right edge: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Unclip the right edge: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an opening pick into the bottom right seam between the chassis and keyboard assembly.
    • Slide the pick toward the top right corner to release the remaining retaining clips.
  13. Lenovo IdeaPad 310-15IKB Disassembly, Remove the keyboard assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Remove the keyboard assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 310-15IKB Disassembly, Remove the keyboard assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard assembly off of the chassis.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
Connor
crwdns2935283:003/29/22crwdne2935283:0
15.192 crwdns2915208:0crwdne2915208:0
crwdns2935297:074crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.526crwdne2935297:0
crwdns2942667:0crwdne2942667:0 53
