Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement
  1. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screw driver to remove:
    • Six 5.0 mm screws
    • Four 3.0 mm screws
  2. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to pry the bottom cover from the device.
    • Use the opening tool to go around the entire perimeter, releasing the tabs that secure the cover to the frame.
    • Insert opening picks between the bottom cover and the frame to prevent the case from reconnecting.
    • Carefully remove the cover.
  3. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the three screws securing the battery to the frame.
    • Be sure not to lose the screws, as you'll need them for the new battery as well.
  4. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the sliding connector to "walk" it out of its socket on the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  5. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from the laptop.
  6. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Solid State Drive (SSD): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Solid State Drive (SSD): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Solid State Drive (SSD): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the SSD.
    • Use a Phillips #00 screwdriver remove the single screw securing the SSD to the frame.
    • Set the screw aside to use for the replacement SSD.
  7. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide SSD from the socket on the motherboard.
    • Hold the SSD by its edges, avoiding contact with any of the exposed circuits or connectors.
    • Be careful when removing the SSD that you don't bend the connecting pins.
    • When replacing the SSD, make sure the pins are aligned correctly with the socket before insertion. Avoid pushing on the drive too hard—once it’s lined up correctly, it should click into place without requiring excessive force.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Collin
crwdns2935283:010/24/24crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 2-2, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S2G2
crwdns2942667:0crwdne2942667:0 175
