Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement
  1. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before beginning, discharge the battery below 25%, power the device off, and disconnect all peripherals.
    • Use a Phillips #1 screwdriver to remove the following screws:
    • Six 7 mm screws
    • Four 4 mm screws
  2. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam between the lower case and chassis.
    • Slide the pick around the entire perimeter until all of the plastic retaining clips release.
    • Remove the lower case.
    • Forcing the back cover open could break the plastic retaining clips.
    • During reassembly, lay the cover flat and press around the edges to secure it to the plastic clips.
  3. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Lenovo IdeaPad 3-15IML05 Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Lenovo IdeaPad 3-15IML05 Battery Disconnection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger or your fingernail to gently push the JST battery connector out of its socket.
    • Pulling directly on the cable could damage the connector.
  4. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Solid State Drive (SSD): crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Solid State Drive (SSD): crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement, Solid State Drive (SSD): crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the SSD.
    • Use a Phillips #00 screwdriver remove the single screw securing the SSD to the frame.
    • Set the screw aside to use for the replacement SSD.
  5. Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-15IML05 Solid State Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide SSD from the socket on the motherboard.
    • Hold the SSD by its edges, avoiding contact with any of the exposed circuits or connectors.
    • Be careful when removing the SSD that you don't bend the connecting pins.
    • When replacing the SSD, make sure the pins are aligned correctly with the socket before insertion. Avoid pushing on the drive too hard—once it’s lined up correctly, it should click into place without requiring excessive force.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Collin
crwdns2935283:010/24/24crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Santin Fall 2024 crwdns2935289:0UMass Dartmouth, Team 2-2, Santin Fall 2024crwdne2935289:0
UMASSD-SANTIN-F24S2G2
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 500
