Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement
  1. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Orient the laptop so that the bottom is facing up.
    • Remove the six 7 mm screws using a Phillips #00 screwdriver.
    • Remove the four 4 mm screws using a Phillips #00 screwdriver.
  2. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry up the sides of the back case using the iFixit opening tool. Then, lift to remove.
    • You may hear snapping when removing the panel. This is normal!
  3. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 4 mm screws connected to the battery pack using a Phillips #000 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Gently lift up the battery pack by hand to remove it.
    • Be sure to avoid pulling the plug cable.
  4. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, SSD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, SSD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, SSD: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel away the blue thermal pad, revealing the SSD underneath.
    • Do not set the sticky bottom side of the thermal pad on any surface.
  5. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 mm screw keeping the SSD in place using a Phillips #00 screwdriver.
  6. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the SSD out straight, without applying any vertical pressure.
    • When removing, do not pull the SSD upwards. This may damage the motherboard slot and hard drive.
  7. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Wi-Fi Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Wi-Fi Card: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail or an opening tool to gently pull out and disconnect the battery pack cable.
    • Do not pull on the cables.
  8. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to remove each cable from the Wi-Fi card, one cable at a time.
    • The cables do not need much force to be removed.
  9. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single 2 mm screw using a Phillips #00 screwdriver.
    • Try not to press to hard down on the computer to avoid damage.
  10. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the card away from the housing capsule on the right side of the Wi-Fi card to remove it from the laptop.
    • Make sure no cables are still connected or wrapped around the Wi-Fi card when removing.
  11. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Fan: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Fan: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernails to gently "walk" the fan connector out of its motherboard socket.
    • Be gentle while unplugging the connector. Using too much force may damage the computer.
  12. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 5.5 mm screws that secure the fan with the Phillips #0 screwdriver.
  13. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unwrap the wires from around the outside of the fan.
    • Remove the fan.
  14. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, RAM: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, RAM: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  15. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disengage the latch of the RAM by pushing outwards on the left and right side of the memory module slot.
  16. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the RAM by sliding it out of its slot.
  17. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Heat Sink: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Heat Sink: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Heat Sink: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3 mm Phillips screws that secure the heat sink.
    • Gently lift the heat sink up and out.
    • Reapply thermal paste before installing a new heatsink.
  18. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the black ZIF locking flap and disconnect the display connector.
    • Use your fingernails to gently "walk" the white CMOS battery connector out of its motherboard socket.
  19. Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 3-1481W000NGUS Motherboard Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven 4 mm Phillips #00 screws securing the motherboard to the chassis.
    • Lift one corner gently. Check for any remaining connected cables, and carefully remove the motherboard out of the case.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Keith Heath II
crwdns2935283:009/19/24crwdne2935283:0
85 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-2, Coppersmith Fall 2024 crwdns2935289:0University of North Texas, Team 2-2, Coppersmith Fall 2024crwdne2935289:0
UNT-COPPERSMITH-F24S2G2
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 307
