This Replacement Guide shows step by step how to replace the Wi-Fi card on a Lenovo IdeaPad 3 Chrome 15IJL6.
Use a Phillips screwdriver to remove the nine 4 mm screws that secure the lower case. hrome 15IJL6
Insert an opening pick into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Use the flat end of a spudger to push the battery connector directly out of its motherboard socket.
Locate the Wi-Fi module in the top center.
Use the pointed end of a spudger to lift and disconnect the antenna Wi-Fi module connectors.
Grip and pull the Wi-Fi module directly out of its motherboard socket.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
