Lenovo IdeaPad 120s-14IAP Battery Replacement
  1. Lenovo IdeaPad 120s-14IAP Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo IdeaPad 120s-14IAP Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo IdeaPad 120s-14IAP Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five 1.5mm Phillips screws from the battery edges.
    We found that a Phillips 00 head works for this step/
    Kyle P Sumpter - crwdns2934203:0crwdne2934203:0
  4. Lenovo IdeaPad 120s-14IAP Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a spudger to unlock the wide ribbon cable's ZIF connector.
    • To unlock a ZIF connector, flip up the small, hinged locking flap.
    • Gently pull the connector from the battery side until it is fully detached from the daughterboard.
  5. Lenovo IdeaPad 120s-14IAP Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the power harness away from the daughterboard until the connector is detached.
    • Pull parallel to the board, not straight up.
  6. Lenovo IdeaPad 120s-14IAP Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the laptop oriented so that the long edge faces you and the battery is closest to you, carefully remove the battery by lifting on the longitudinal edge.
    • Pull the battery directly towards you and out from under the forward retaining strap.
Kyle P Sumpter
crwdns2935283:009/17/19crwdne2935283:0
363 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G4, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G4, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G4
Thank you for showing exactly how to remove the battery connections, thanks!
Erik Gunnar Gervin - crwdns2934203:0crwdne2934203:0
Great guide. I may well need a new battery but would appreciate your comment. Battery shows charging but never gets above 0%
When I put a meter at the 2 red cables they show zero volts (even when computer on, and showing charging). Other wires are ~1.6v & 3.4v.
Could I have a faulty battery or something else?
Colin Kinsella - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,559
