Lenovo IdeaPad 110-15IBR Battery Replacement
  1. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo IdeaPad 110-15IBR Battery Replacement, Remove screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you proceed, make sure your computer is turned off and it's not connected to any power source.
    • Remove the thirteen 9 mm Phillips #1screws.
    • Pull out the DVD drive and unscrew the final 3 wide-head screws holding the back in place.
    Attention ! Sur le mien, il faut après avoir retiré la vis au dessus de l’étiquette blanche, faire coulisser le lecteur dvd vers l’extérieur (la vis le maintenait en place).
    Une fois celui-ci retiré apparaissent les 3 dernières vis à retirer pour pouvoir retirer le boitier inférieur sans souci.
    Dominique ENET - crwdns2934203:0crwdne2934203:0
  2. Lenovo IdeaPad 110-15IBR Battery Replacement, Remove the back: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the back off using a plastic opening tool, starting from one of the corners.
  3. Lenovo IdeaPad 110-15IBR Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 9 mm Phillips #1 screws holding the battery.
  4. Lenovo IdeaPad 110-15IBR Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 110-15IBR Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo IdeaPad 110-15IBR Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery cable connector from mother board.
    • Remove battery from device.
    I would suggest that you inform the people that the battery slides out away from the hinge area. I had to work at getting the battery to move and then i saw where the battery slides out on two plastic pieces. Thank you for the tutorial.
    Darren - crwdns2934203:0crwdne2934203:0
crwdns2935229:019crwdne2935229:0
Saddam Alsinai
crwdns2935283:010/18/17crwdne2935283:0
690 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S3-G4, Liner Fall 2017 crwdns2935289:0UW Tacoma, Team S3-G4, Liner Fall 2017crwdne2935289:0
UWT-LINER-F17S3G4
crwdns2947412:023crwdne2947412:0
Informative except , you didn’t mention the three screws underneath the DVD drive. The DVD drive must be removed first before you can remove the 3 additional screws.
Clarey Ryan - crwdns2934203:0crwdne2934203:0
I agree Clare! I didn’t see those either! Very frustrating at first! Thanks for the lead Clare!
Daniel Jansen - crwdns2934203:0crwdne2934203:0
Just cannot see where theres 13 screws got 11 cant see anything under or near the Drive clare.
charlie.bansj - crwdns2934203:0crwdne2934203:0
I unscrew everything but to open it, it gets stuck in the middle….. i am afraid to pull hard…..
djerro - crwdns2934203:0crwdne2934203:0
Thus the media in the laptop remains as it is?
shradha patil - crwdns2934203:0crwdne2934203:0
brand new out of the box and it is frozen……..how can I get this returned
Karen Galib - crwdns2934203:0crwdne2934203:0
DO NOT try to remove the back without pulling the DVD drive and unscrewing the additional three screws!!! You'll break the thinnest part of the back. This guide erroneously makes no mention of these three flat screws.
Lan Sharked - crwdns2934203:0crwdne2934203:0
Remove all the bottom screws Then You have to remove the keyboard before you can get the back off. Back center screw by the decal is for keyboard. The lightly pry off keyboard. 3 screws (1 screw under round sticker) under it have to be removed. Remove DVD. Then back will come off.
rknapp1 - crwdns2934203:0crwdne2934203:0
Lenovo ideapad 110-15
(I am referring here to the model: Lenovo ideapad 110-15 ISK, model name: 80UD)
To Open the Laptop insides (Step 1)
To Remove the DVD Player (Steps 1 and 2)
To Remove the Battery (Steps 1 to 3)
To Remove the Hard drive (Steps 1 to 4)
Firstly, to Open the Laptop insides (Step 1)
1. Remove all the bottom screws (11 of them). Two of the eleven (in the middle) are for the keyboard, and the other one close to those in the middle, is for the DVD Player.
1a. Turn over the Laptop, so that the Keyboard faces you.
1b. Gently pry off the Keyboard. You can start from the top (small hooks) or from the bottom right (close to you) between the Key on the Keyboard marked [0 / INS] and [. / DEL] of the number keys. The 6 plastic hooks underneath, are situated at the edge of the Keyboard at the following keys: [. / DEL], [Down-arrow / PgDn], [Right-ALT], middle of [Space bar], left of {Space bar], and between [CTRL] and [FN].
1c. Gently tilt the Keyboard and turn it over towards you. ... (see next comment) ...
Peter Maas - crwdns2934203:0crwdne2934203:0
(I am referring here to the model: Lenovo ideapad 110-15 ISK, Model name: 80UD)
To Open the Laptop insides (Step 1),
Remove DVD player (Steps 1 and 2),
Remove Battery (Steps 1 to 3),
Remove: Hard drive (Steps 1 to 4)
Firstly: To open the Laptop insides (Step 1)
Step 1.      Remove all the bottom screws (11 of them). 2 of the 11 (in the middle opposite each other) are for the keyboard, and the other one close to those two in the middle, is for the DVD player .
a.      Turn over the laptop and open it by lifting the screen panel, so that the keyboard faces you.
(See: next comment)
Step 1c.      Gently tilt the keyboard and turn it over towards you. Be careful – the connector cable is attached to the board underneath it.
d.      Remove the screw to the right of the FAN (under the sticker) That one screw is holding the Bottom cover – 2 more screws to go if you need to loosen the Bottom cover!
e.      Position the keyboard over its place, without putting it back in.
f.      Turn over the laptop.
To remove DVD Player: (Steps 1 and 2)
Step 2.      Slide the DVD player out and remove.
Continued in next comment)
Peter Maas -
(continued from previous comment. Be sure to follow Steps chronologically)
Step 1 c.      Gently tilt the keyboard and turn it over towards you. Be careful – the connector cable is attached to the board underneath it.
(continued on next comment)
Peter Maas -
(continued from previous comment) To open the Laptop insides (Step 1)
ce      Position the keyboard over its place, without putting it back in.
(continued in next comment)
(continued from previous comments) Be sure to follow the steps chronologically...
To remove Bottom cover, and then Battery: (Steps 1 to 3)
Step 3.      Remove the 2 screws under where the DVD player came out.
a.      Turn over the laptop.
b.      Gently pry off the bottom cover of the laptop, starting from above the hinges of the screen (=top part of laptop).
c.      Remove the 2 remaining screws holding the battery in place.
d.      Then gently turn over the bottom cover. You will see the battery connector cable attached to the main board.
e.      Gently pull out the Connector cable at the point where it connects with the main board.
f.       Remove the battery.
(continued from previous comments) ... be sure to follow the Steps chronologically ...
To remove Hard drive (Steps 1-4):
Step 4.      Remove the 6 screws holding the Hard drive.
a.      Slide the Hard drive out.
That's it! I hope that helps.
1.      Remove all the bottom screws (11 of them). 2 of the 11 (in the middle) are for the keyboard, and the other one close to those two in the middle, is for the DVD player .
a.      Turn over the laptop so that the keyboard faces you.
I posted 4 different consecutive COMMENTS, but do not see them here!
Contact me for the rest of the instructions
Peter Maas -
(continued from previous comment(s): be sure to follow the Steps chronologically)
To remove DVD Player: (do Steps 1 and 2)
(see next comment)
ifixit, where are the rest of the comments I posted? Please look at your Comments section on your website.
Unter der tastatur noch eine zusäzliche schraube
Gion Wurster - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 58
crwdns2936753:030crwdne2936753:0 148
crwdns2942667:0crwdne2942667:0 49,040
