Lenovo Essential G560 RAM Replacement and install 4gb RAM
Dennis Wong
crwdns2944107:0crwdnd2944107:0Dennis Wongcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 21, 2024crwdne2944111:0
1 - 5 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
RAM should be replaced if the computer has memory issues. This is sometimes the case when the computer won't boot, or simply runs too slow for comfort.
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
crwdns2944105:0crwdne2944105:0
  1. Lenovo Essential G560 RAM Replacement and install 4gb RAM, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 RAM Replacement and install 4gb RAM, Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
    a few of my screws are not coming out
    Jonathan Lewin - crwdns2934203:0crwdne2934203:0
    Same here. I was able to easily remove the 2 middle screws but the rest were just wiggling in place and not coming out at all.
    Denskwik K - crwdns2934203:0crwdne2934203:0
    I have the exact same problem. I dont know if it is because of the screws or if it is because I am an 11 year old.
    Alex Kuriakose - crwdns2934203:0crwdne2934203:0
  5. Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
    I was having the same problem as the 11 year old from the previous step, and contrary to this note I just stuck my screwdriver under that tab and pried it off. It worked. It wasn’t even hard.
    lmh237 - crwdns2934203:0crwdne2934203:0
  6. Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
  7. Lenovo Essential G560 RAM Replacement and install 4gb RAM, RAM: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Essential G560 RAM Replacement and install 4gb RAM, RAM: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the RAM Sticks in the computer. They should be in the corner of the laptop.
  8. Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, push one of the metal rods on either side of the RAM stick away from it until you hear a light clicking noise. Repeat this procedure on the other metal rod on the opposite side of the RAM stick.
    • If you push both metal rods away from the RAM stick as directed, the RAM stick will pop up at an angle.
  9. Lenovo Essential G560 RAM Replacement and install 4gb RAM: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull out the stick of RAM.
    • If you wish to remove the second stick of RAM, do so by following steps two and three again.
crwdns2935229:05crwdne2935229:0
Dennis Wong
crwdns2935283:001/11/13crwdne2935283:0
609 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-40, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 18-40, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S18G40
crwdns2935297:013crwdne2935297:0
maine apne lenovo g560 laptop me crucial 4gb ram add kiya lekin mera system format nahi ho raha h. mujhe kya karna chahiye mujhe email kare. vikasmaddeshiya056@gmail.com
vikkivikas056 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,327
