Lenovo 300e Chromebook 2nd Gen Trackpad Replacement
  1. Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Opening The Chromebook: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Opening The Chromebook: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Opening The Chromebook: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Phillips #0 Screwdriver
    $5.49
    • Make sure you power off your Chromebook first as you will be disconnecting the battery!
    • Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
    • The screws circled on this Chromebook's back casing are all identical!
    • Use an opening tool such as a spudgerand carefully work your way around the laptop to remove the back cover
  2. Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Disconnect the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Disconnect the Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
  3. Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 screws holding in the battery and set them aside
    • Make sure to separate the screws for the battery from the screws for the backing that were removed in the first step!
  4. Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Remove Trackpad Screws & Connector: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Remove Trackpad Screws & Connector: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Remove Trackpad Screws & Connector: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $5.49
    • Disconnect the Trackpad Cable by lifting the Connector.
    • Remove the 3 screws holding in the top of the trackpad with a Phillips #0 screwdriver
  5. Lenovo 300e Chromebook 2nd Gen Trackpad Replacement, Remove Trackpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Spudger
    $3.99
    • Please make sure the Chromebook is open as the trackpad will come out from the inside of the device.
    • There are 3 tabs (2 at the bottom and 1 at the top left of the trackpad), using the Spudger, push the tabs to remove the Trackpad from the case.
Sam Addington
crwdns2935283:009/21/22crwdne2935283:0
189 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 659
