Left Joy-Con Charging Rail Replacement
Peter Lam
crwdns2944107:0crwdnd2944107:0Peter Lamcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Sun 18, 2025crwdne2944111:0
crwdns2931287:030crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
A broken charging rail will cause an inability to connect directly to the Nintendo Switch console or an inability to charge the Joy-Con. This guide will show you how to replace the charging rail on the Left Joy-Con controller.
Before using this guide, check for potential bent pins on the charging rail that can be bent back. If possible, test if the Joy-Con can be charged from an external source or check if the problem is actually with the sensor rail on the Nintendo Switch console.
If the problem is the Nintendo Switch sensor rail, then follow this guide: Nintendo Switch Left Joy Con Sensor Rail Replacement
crwdns2944105:0crwdne2944105:0
  1. Left Joy-Con Charging Rail Replacement, Charging Rail: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Joy-Con Charging Rail Replacement, Charging Rail: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Tri-point Y00 screwdriver to remove the four 6 mm screws from the back of the Joy-Con.
  2. Left Joy-Con Charging Rail Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opening pick into the bottom of the Joy-Con, then move it towards the L and ZL buttons.
    • Lift the back shell off the Joy-Con and place it to the side.
    • Be careful when removing the back shell as it is connected to two ribbon cables by the charging rail and motherboard. Potential for device damage may occur if it is yanked apart.
  3. Left Joy-Con Charging Rail Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger or prying tool beneath the battery wires and gently pry the battery plug out of the socket on the motherboard.
    • Once the battery plug is removed from the socket, lift the battery off the mid-frame.
    • A spudger is recommended for this step if one is available. If not, use an ESD safe tool.
  4. Left Joy-Con Charging Rail Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three golden 3 mm Phillips #000 screws holding the mid-frame in place.
    • Lift the mid-frame off the motherboard and place it to the side.
    Be mindful of your L button on top, as it's not secured in placed once this plate is removed. If it comes off without intention, make sure you find and keep the spring with it
    Ross Montgomery - crwdns2934203:0crwdne2934203:0
  5. Left Joy-Con Charging Rail Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the ZIF connector that is locking the ribbon cable on the mid-frame to the motherboard.
    • Use tweezers to gently pull the ribbon cable out of the ZIF connector.
    This step (disconnecting the midframe cable) is not strictly necessary, but if you don’t do it the frame can get in the way during reassembly.
    Guy Bolton King - crwdns2934203:0crwdne2934203:0
  6. Left Joy-Con Charging Rail Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch the two ZIF connectors that are locking the ribbon cables on the charging rail to the motherboard.
    • Use tweezers to gently pull the ribbon cables out of the ZIF connectors.
    How do you unlatch the connections.
    Winston Buentello - crwdns2934203:0crwdne2934203:0
    The top connector has a latch; raising the cable slightly or prising in the slot on the side will release it. There is no latch on the bottom connector; just gently ease the cable out.
    The bottom connector absolutely DOES have a ZIF connector, but it's on the opposite side. The tweezers in the second picture are pointing directly at the connector, and it slides up to the left (from the perspective of the picture).
    Rob Hulson - crwdns2934203:0crwdne2934203:0
    That little grey piece on the bottom connector flew off the connector when I put a spudger under it. I can't get it back on regardless of what I've tried, so I'm likely to leave it off rather than risk bending pins. Looks like this little grey piece is wedged between two tuning fork shapes for each pin. If anyone knows the connector name I'd love to take a look at the datasheet as the disconnect/reconnect is making no sense to me.
    Bo Buckley - crwdns2934203:0crwdne2934203:0
    Took me ages to figure out how to put it back on. Just make sure you lift it up to rotate it rather than push it back parallel with the board (like some other connectors). See here for how to replace it if it flies off (and you can find it) :D
    Repositionnement du clapet de connecteur de nappe flexible
  7. Left Joy-Con Charging Rail Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2 mm Philips #000 screw holding the charging rail onto the back shell.
    • Remove the charging rail from the back shell.
    • There is an adhesive tape that helps keep the charging rail in place on the back shell. When placing the new charging rail onto the back shell, it is advised to also replace the adhesive to add extra support, but it is not essential.
  8. Left Joy-Con Charging Rail Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #000 screwdriver to remove the two 3 mm screws at the center of the PCB.
    • Remove the PCB from the charging rail.
  9. Left Joy-Con Charging Rail Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SL, SR and sync buttons from the charging rail.
    If the new charging rail does not have the syncing led extenders, you can take them out and transfer them as well.
    Kallon Lewallen - crwdns2934203:0crwdne2934203:0
  10. Left Joy-Con Charging Rail Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the SL, SR and sync buttons into the new charging rail and make sure the tabs on the SL and SR buttons fit into their respective socket grooves.
    • Place the PCB over the buttons and secure it in place using the two golden 3 mm Phillips #000 screws.
    • Potential for device damage. If the buttons are not properly placed into the charging rail, proceeding to screw in the PCB will cause it to warp.
  11. Left Joy-Con Charging Rail Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the charging rail with the two standoffs on the back shell.
    • Secure the rail onto the back shell using the 2 mm Phillips #000 screws.
    There’s only one Phillips screw, the upper one, as removed in step 7.
  12. Left Joy-Con Charging Rail Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to insert the ribbon cables for the charging rail into the ZIF connectors on the motherboard.
    • Press down on the latch for each ZIF connector to secure the ribbon cables in place.
    Had a pretty hard time reconnecting this one, ZIF connector opened back up quite a few times. So make sure not to put too much strain on the cable
    Mart - crwdns2934203:0crwdne2934203:0
    Note also that there is no latch on the lower cable.
    On a Switch OLED Joy Con, both ZIF connectors have latches, one is black and one is the same color as the port
  13. Left Joy-Con Charging Rail Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to insert the ribbon cable for the mid-frame into the ZIF connector on the motherboard, with the golden pins facing upwards.
    • Press down on the ZIF connector latch to secure the ribbon cable in place.
  14. Left Joy-Con Charging Rail Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the the mid-frame over the motherboard.
    • Using Philips #000 screwdriver, secure the three golden 3 mm screws of the mid-frame onto the motherboard.
    • When placing the mid-frame onto the motherboard, the bumper button may come loose. To reattach the bumper button, first insert the spring on the bumper button into the groove located on the top left side of the Joy-Con, then insert the right side of the bumper button into the Joy-Con.
  15. Left Joy-Con Charging Rail Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the battery into the mid-frame.
    • Use tweezers to align the battery plug over the socket and with a pry tool or an object with a flat edge, press the plug into the socket.
  16. Left Joy-Con Charging Rail Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Joy-Con Charging Rail Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the charging rail into the notch on the left side of the Joy-Con.
    • Apply even pressure on both sides of the Joy-Con until the two shells click together.
    • Screw in the four 6 mm Tri-point Y00 screws into the back of the Joy-Con.
crwdns2935229:038crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Peter Lam
crwdns2935283:009/19/20crwdne2935283:0
1,879 crwdns2915208:0crwdne2915208:0
York University, Team S1-G14, O'Regan Summer 2021 crwdns2935289:0York University, Team S1-G14, O'Regan Summer 2021crwdne2935289:0
YORK-O'REGAN-SU21S1G14
crwdns2947412:017crwdne2947412:0
I did this and still doesn’t work. I also changed the rail on the console side too. Very carefully of course. Any ideas?
Luis - crwdns2934203:0crwdne2934203:0
Hey Luis,
Can you give me more detail on the problem? Like is the Joy-Con not being detected when it’s plugged in or is it not charging. If possible, can you test the console rail with a working Joy-Con?
If the Joy-Con is not charging, it could also be a battery problem. If you are comfortable with it, I would suggest swapping out the battery with a working one from the other Joy-Con to see if it solves the problem. You should probably attempt this after double-checking the connections for potential tears or if the connectors are too loose in the sockets.
Peter Lam -
Hi, I need help. My left Joy-Con is not charging because of the ZIF connector for the charging rail ribbon has been detached and I have lost it. Is there a way to fix this problem?
Jakkrij Sihanatkathakul - crwdns2934203:0crwdne2934203:0
Honestly, I would recommend replacing the entire Motherboard, unless you can find a trusted repair shop to solder it on.
I damaged the ZIF connector for the battery on my Switch. It works with some pressure and perfect alignment, but I've had issues ever since I damaged it during repairs :/
I'm going to swap it with a functional motherboard, I would advise you do the same.
Yakarot Sennin -
Hello need a little help. the ribbon cable will not stay connected. and it will not charger. Any thing will help.
Matthew Molt - crwdns2934203:0crwdne2934203:0
I damaged my joy con and the lower ribbon wire that connects to the battery has burned out. Is there anyway I can get another set of wires or what not?
Alberto huntington - crwdns2934203:0crwdne2934203:0
Hi There, i trust a bad guide not from here, and seemed to have broke the charging ribbon attachment area. Any way to fix it?
in this guide, it would be step 6, second image. the black part that wraps around the ribbon when it is attached is ripped in half. Some other youtuber said to detach the latch from the front, which i tried. but it was actually in the rear. because he didn't show the step clearly, figured it was that. As i've seen other laptop ribbon latches are similar, pull the thing out, and it pops out. in this case, that was a ribbon connector, and the latch is a flip latch from the rear...
hope you can help. thanks.
Alex - crwdns2934203:0crwdne2934203:0
What if the charging rail is totally broken off? Like, it was pushed off the counter by a small child and the charging rain is totally torn off from the controller
Allie Diane - crwdns2934203:0crwdne2934203:0
If both ribbon cables are completely severed on the rail then you would probably have to also buy a SL/SR PCB replacement. The process would still be the same just use the new SL/SR PCB and make sure that the PCB is for the correct joycon. If you want to find it, you can search for SL SR flex cable or sometimes they are also sold with a new charging rail.
Peter Lam -
I forgot to mention if you broke the peg on the back shell then you may need to replace the back shell. Alternatively, you can try to glue it back together, but if you do, you should check if it can withstand a bit of pressure.
Peter Lam -
Hello. I changed the charging rail and the sr/sl board but my controller won’t connect to my switch. I’ve also swapped the charging rail again to see if that’s the issue and not it won’t charge. The ribbon is in damaged so I’m confused
XxDemon:3 - crwdns2934203:0crwdne2934203:0
Hi I need someones help with my right joy con stick's charging rail. It is charging alright but it's not connecting to my switch in hand-held mode. Is it possible that somebody could post a tutorial like this but for the right joy con? It will really help me a bunch. Thanks.
Toasty - crwdns2934203:0crwdne2934203:0
I would also like this tutorial but for the Right Joy Con. I would've assumed they are similar, but since the guides are labelled very specifically per side, I'd rather not risk it.
My Right Joy Con is not recognised by the Switch, wirelessly or when attached. As a result it doesn't charge, and so It's now off permanently :(
PuyoBop -
Is there a video of this guide?
Liran Belzer - crwdns2934203:0crwdne2934203:0
When removing the battery using the tweezers as shown the socket also detached with the battery connector. I didn’t know I could just gently remove them with my fingers…. is there any way to reattach the socket to the motherboard properly? I used nail glue, and now the joycon wont charge and my switch isn’t reading the it. Sometimes it shows but it will only work when connected to the switch.
Tia LaShay - crwdns2934203:0crwdne2934203:0
This guide also works for the Joy con right?
Iago Gamer Pro - crwdns2934203:0crwdne2934203:0
Thank you! I used this guide to fix a bent pin in a Joycon. I had to use a microscope to see the pin, but it works after bending back.
Mark Parnaby - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 74
crwdns2936753:07crwdne2936753:0 551
crwdns2936753:030crwdne2936753:0 2,656
crwdns2942667:0crwdne2942667:0 104,785
