Left Controller
Left Controller
thetechguy
crwdns2944107:0crwdnd2944107:0thetechguycrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 4, 2024crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2944105:0crwdne2944105:0
  1. Left Controller, Remove rear screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Controller, Remove rear screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Controller, Remove rear screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the left controller and locate the four screws.
    • Remove the four PH0 screws.
    • Warning: A small ribbon cable connects the two halves of the controller, so be careful when opening.
    Where can i buy the ribbon cable?
    holgazanear - crwdns2934203:0crwdne2934203:0
    I doubt you can buy parts for these. You would have to salvage from another controller or attempt to repair the cable with micro-soldering.
    thetechguy - crwdns2934203:0crwdne2934203:0
  2. Left Controller, Open controller halves: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Controller, Open controller halves: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Warning: The two halves easily come apart, but the small ribbon cable between them can easily be damaged.
    • Lift the back half slightly off the front half and fold it open along the left edge.
    • The ribbon cable is circled in the second image.
  3. Left Controller, Disconnect ribbon cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Controller, Disconnect ribbon cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Controller, Disconnect ribbon cable: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic spudger to flip the ribbon cable latch up as shown in the first two images.
    • Remove the ribbon cable from the slot by pulling gently to the left with tweezers or fingers.
    where can i bought this part?
    Which part? The ribbon cable, the connector, the spudger, or the entire Left controller?
    thetechguy -
    the ribbon cable or all the part where the ribbon cable is soldered
    holgazanear -
    how do i reconnect the ribbon cable?
    Kj Flowers - crwdns2934203:0crwdne2934203:0
  4. Left Controller, Disassemble back half: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Controller, Disassemble back half: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one PH00 screw that is securing the rail to the back half.
    • The FL button can be removed by placing a lever/spudger under the circled area.
    • The rail connector can be removed once the yellow circled screw is removed.
    • The button that releases the buckle lock can be removed after the rail and goes in the hole circled on the back half of the controller.
    • The one remaining screw does not need to be removed as it only secures a bit of plastic.
  5. Left Controller, Disassemble Rail: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Left Controller, Disassemble Rail: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three PH00 screws.
    • Pry out the metal cover over the buckle lock. Be gentle so as not to bend the metal.
    • The spring loaded buckle lock can then be removed. NOTE: Do not loose the spring when disassembling. Reassembly can be tricky because the spring needs to be compressed to get back in place.
    • The plastic cover over the holes in the middle of the rail can be removed. This is where SL, SR, and connect buttons would be on a normal Joy Con controller and also the lights indicating which controller number it is.
  6. Left Controller, Front Half - ZL & L buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Controller, Front Half - ZL & L buttons: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Controller, Front Half - ZL & L buttons: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ZL button can be removed once the red circled screws are removed.
    • The L button is underneath the ZL button and is easily removed once the ZL button is out of the way. There is a small hole that one end of the L button fits into.
    • Remove four PH0 screws, two that hold in the ZL button plastics and one on the top button board and one of the two screws securing the main motherboard.
    • Warning: Do not try to remove the top button board before you remove this small button board in the next step.
  7. Left Controller, Small L button board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Controller, Small L button board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Controller, Small L button board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The small L button board is slid into a slot and has delicate wires that connect it to the top button board.
    • Clasp on both sides of the small L button board with your fingers and wiggle it out.
    • The top button board is connected to the main motherboard with the circled connector.
  8. Left Controller, Top and main boards: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Left Controller, Top and main boards: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Left Controller, Top and main boards: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here you can see the connector that joins the top button board and main motherboard. Pull directly up on the top button board and the entire board will come loose. This board also has the joystick control on it.
    • One remaining screw appears from under the top button board; remove.
    • The minus button can be removed. Notice the orientation and that there are two pin holes that the front half plastics poke through.
    • The processor for the controller can be seen on the main motherboard. See the details in Step 9.
    • The main motherboard can be removed and as well as all remaining rubberized/plastic buttons.
  9. Left Controller, MM32L052NT CPU: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the only microchip on any of the boards.
    • This is a MM32L052NT chip from China that is a 32 bit ARM Cortex(TM) M0 with 48MHz CPU, 32K NVRAM, 4K SRAM, and various I/O interfaces.
    • Datasheet available here: http://www.mm32mcu.com/userfiles/images/...
crwdns2935229:05crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
thetechguy
crwdns2935283:012/12/15crwdne2935283:0
786 crwdns2915208:0crwdne2915208:0
crwdns2947412:07crwdne2947412:0
This was very helpful! Thank you for the tutorial
general_pigface - crwdns2934203:0crwdne2934203:0
Would anyone like to venture a guess as to whether I could snag a generic joystick to solder in place of the existing one? Maybe it has a part number printed on it or the corresponding board? The left thumbstick isn't working correctly on mine after approximately a year of use. I used to replace drifting thumbsticks in Xbox 360 controllers without much trouble at all and I'd love to salvage my Split Pad if at all possible.
Ryan Hall - crwdns2934203:0crwdne2934203:0
Ryan, I have previously commented on another post that the joystick looks like an exact match for the Xbox 360 controller joystick. I would suggest you give it a try.
thetechguy -
Thank you for the writing this guide. It is very helpful. Is there anywhere you know of that sells replacement ribbon cables? It has detached from the latch and I am not sure if it is salvageable.
Thanks a lot.
keen2fixstuff - crwdns2934203:0crwdne2934203:0
Doubtful that you'd be able to find a replacement unless you have another set of the same controllers. The ribbon cable is supposed to come out of the latched cable connector like shown in Step 3. You should be able to put it back into the cable connector and flip the latch back down to hold it in. The cable connector is very flat and the ribbon cable only fits in from the one direction. Hope that helps.
thetechguy -
Hello,
I have not found anywhere an explanation on how to repair a Split Pad Pro that is not recognized by the Switch. It can't be the console itself, because I tried another Split Pad Pro on the site and it worked fine, just like the standard Joy-Cons of the Switch. Now I've been trying since yesterday to find a tutorial or service for my Left Split Pad Pro that I can use to fix it.
Maybe someone here knows more? If this is still being read at all XD
Veyilla - crwdns2934203:0crwdne2934203:0
If it isn't detected by the switch, then you likely have a severed ribbon cable (shown in Step 4) or a faulty MM32L052NT (shown in Step 9). This isn't a complicated product, but you'd never be able to replace the MM32L052NT and reprogram it (you lack the source code).
thetechguy -
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 100
crwdns2942667:0crwdne2942667:0 10,283
