Lefant M210 Battery Replacement
  1. Lefant M210 Battery Replacement, Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement, Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the Lefant M210 over to have a clear view of the brushes.
  2. Lefant M210 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the blue tool under the circular part of the brush in the center
    • Push down the other end of the tool to pop out the brush component
    • When replacing, align the bottom of the brush with the connector on the vacuum and push down to set it in place.
  3. Lefant M210 Battery Replacement, Wheel Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove four screws near each wheel.
  4. Lefant M210 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic cover next to each wheel.
    • Grip both sides of the wheel and pull upwards.
    • The wheels of the device require some force to remove.
    • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
  5. Lefant M210 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the wheel up and detach the connector to release it from the device.
  6. Lefant M210 Battery Replacement, Dustbin Filters: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the dustbin compartment.
  7. Lefant M210 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your hands, gently pull the dustbin to remove it from its compartment.
  8. Lefant M210 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With your hands, pull off the filter compartment from the dustbin.
  9. Lefant M210 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the filter from the filter compartment.
  10. Lefant M210 Battery Replacement, Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
  11. Lefant M210 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully flip the vacuum back right-side-up, making sure you're holding it all together so that the bottom portion doesn't fall out.
    • Rotate the vacuum so that the Lefant logo is facing you.
    • Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
    • Rest the open cover something stable, like a wall.
  12. Lefant M210 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
  13. Lefant M210 Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the motherboard, ensuring you don't rip any cables that are connected to it.
    • The battery should be under the motherboard.
  14. Lefant M210 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
    • Retaining clips
    • Battery tabs
    • Work on freeing one side at a time so that it's easier to free the battery.
  15. Lefant M210 Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the battery is free from it's housing, lift it out completely using its pull tabs.
  16. Lefant M210 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery connection wire and carefully pull apart the connection.
    • Pinch the motherboard's wire connector and pull the connection apart.
    • The connection is secured by a clothespin-like mechanism.
    • When you replace your battery with a new one, allow the robot vacuum to fully charge for a few hours before using it again.
    اين اجد البطارية في العراق وبسعر مناسب
    Justin Jameel - crwdns2934203:0crwdne2934203:0
    اين توجد البطارية في العراق وبسعر مناسب
Darien Amador
crwdns2935283:009/09/24crwdne2935283:0
195 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-4, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 2-4, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S2G4
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
Jonathan Manuel - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 27
crwdns2936753:07crwdne2936753:0 132
crwdns2936753:030crwdne2936753:0 590
crwdns2942667:0crwdne2942667:0 2,894
