This guide will show the user how to access and clean or replace the speaker in the Leapfrog My Own Leaptop.
Flip over device so that back portion of the device is facing you.
Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
Remove the three AA batteries.
Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
Remove the cover and place to the side.
Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
What do you do when you "disolder" the cables?
What do you do if the yellow wire is already broken off the silver part? How do you reapply it?
Our white wire is halfway off, so I’m wondering if it can be soldered back on
Speaker measurements (measured with digital caliper):
0.25 W / 16 ohm / 35.5mm diameter (anything smaller will work, but will rattle around)
Yellow wire to leftmost solder point, White wire to rightmost solder point.
Embossed on speaker: 16ohm / M-0.25W / CPC
Also remember to back out the screws to where you hear a “click” before screwing them in (this finds the previous threads so you won’t make new threads in the screwposts).
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
crwdns2947412:05crwdne2947412:0
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
I agree, but I also second the question...where can I buy a replacement speaker?
Where could I purchase a replacement speaker?
Where could I buy the replacement speaker in Malaysia?
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
