The step by step guide is designed to assist with button replacement of the Leapfrog My Own Leaptop.
Flip over device so that back portion of the device is facing you.
Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
Remove the three AA batteries.
Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
Remove the white plastic piece and place it to the side.
Gently grab the membrane and peal it upwards.
Carefully remove the membrane and set it to the side.
From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
Ensure that the membrane is completely dry before reassembly.
Where can i buy the replacement membran? Only letter I and R work
Looks like you having same issue with me Hery.. the membrane is going hirewire. how to fix? can we do the cleaning / where to buy the membrane for replacement
Was there an update on getting a nee membrane? The Paw Button for me is no longer functioning, would love to get a membrane replacement so my kids can continue to use this toy.
Gently lift and remove the foam piece
crwdns2935267:0crwdne2935267:0Tweezers$4.99
From here, each button is able to be removed for cleaning or replacement.
Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
Very useful. but where to get a new membrane? please help
Didn't work. I'll buy a new toy.
Is the screen on this suppose to light up?
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Where can you buy the membrane?
