LeapFrog LeapPad Ultra Repair Speaker Replacement
  1. LeapFrog LeapPad Ultra Repair Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
    A long flat-tip screwdriver can be used to push the tab out from the other side as they hook inwards towards the center. You can see the locations in the step 4 photo near the edges.
    Eric Tong - crwdns2934203:0crwdne2934203:0
  4. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
    My device had the 7mm screw to the right of the cartridge slot and the 2 to the left of the cartridge slot were also 7mm.
    the other 9 were indeed 8mm,
    Mike.
    Mike Gilmour - crwdns2934203:0crwdne2934203:0
  5. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
    This was extremely helpful, and easy to do!! Thank you so much! You saved the day!
    Bailey Condon-Salmon - crwdns2934203:0crwdne2934203:0
  7. LeapFrog LeapPad Ultra Repair Speaker Replacement, Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the screws on the bottom of the device holding down the button and speakers board.
  8. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There should be a plastic covering over the speaker, carefully pull on the opposite side from the plastic clip holding it in place.
    • Excessive force can break the plastic clip, only use enough for to remove it gently
  9. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the button and speaker board, and turn it over, revealing the other side of the board.
  10. LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LeapFrog LeapPad Ultra Repair Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the ribbon cable connection and with a small plastic tool flip the plastic holding it down up.
    • You can now safely remove the ribbon cable by gently pulling it out of the slot.
    • Trying to remove the cable with brute force will damage the cable.
Carlos Ortiz
crwdns2935283:008/24/15crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-99, Meier Fall 2015 crwdns2935289:0USF Tampa, Team 4-99, Meier Fall 2015crwdne2935289:0
USFT-MEIER-F15S4G99
Where can i buy a replacement speaker at to do this?
anthonydesiato2002 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,106
