If the battery is too low for the device to turn on, replacing the battery may be necessary. If the device does not turn on after charging, the battery is most likely completely dead. When a battery is completely discharged, it oftentimes cannot be recharged. In this case, the battery is dead and needs to be replaced. No special skills or tools will be needed in order to complete this guide.
Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
Insert the spudger between the front and back panel in order to pry them apart.
Pry open the rest of the Le Pan S by dragging the spudger across the side.
Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
Disconnect the battery from the circuitry and lay it out of the way.
What is the replacement battery to get? Model,type, anything would help..
what is a spudger? Where do you get it? Are replacement batteries still available somewhere?
crwdns2947412:05crwdne2947412:0
where can I purchase a battery for a tc978
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
Where can I purchase the battery needed?????????????????
Thank you Maria!
Easy to take apart. Disconnected/reconnected battery and voila!
All good.
Be well.
Den E
