Laptop Keyboard Cleaning Guide
  1. Laptop Keyboard Cleaning Guide, Shut It Down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the laptop.
  2. Laptop Keyboard Cleaning Guide, Loose Debris: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Laptop Keyboard Cleaning Guide, Loose Debris: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Laptop Keyboard Cleaning Guide, Loose Debris: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Run compressed air back and forth across the keyboard.
    • If you can, hold or rest your laptop upside-down (so the keyboard is facing the ground) while you perform this step so that the debris will fall down away from the laptop.
    • If you notice something stuck under a certain key, try tilting the laptop to different angles while blowing the compressed air to get it out. Laptop keys have tiny edges on them that can trap debris.
  3. Laptop Keyboard Cleaning Guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • Use a microfiber cloth or a vacuum to remove any debris that the compressed air dislodged from the keyboard.
  4. Laptop Keyboard Cleaning Guide, Grease & Grime: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laptop Keyboard Cleaning Guide, Grease & Grime: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Dampen a microfiber cloth with >90% isopropyl alcohol and wipe down the entire surface of the keyboard, paying special attention to the space between keys, and areas that are noticeably grimy.
    • Isopropyl alcohol that is >90% pure is generally free enough of impurities that it won't damage sensitive electronic equipment, but it's still a good idea to be careful with it! The cloth you use to wipe the keyboard during this step should be damp, not dripping wet.
  5. Laptop Keyboard Cleaning Guide, Sticky Keys: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Laptop Keyboard Cleaning Guide, Sticky Keys: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Laptop Keyboard Cleaning Guide, Sticky Keys: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Picks (Set of 6)
    • If you've got a sticky key or large debris stuck under one of your keys, use an Opening Pick or another thin tool to carefully pry up the keys in question.
    • This can be done by carefully inserting the opening pick into the small gap between the key and the chassis, and gently prying upward.
    • Don't attempt this on Apple laptops with a “butterfly” keyboard (any 2015+ MacBook or 2016+ MacBook Pro). The butterfly mechanism and the extra-thin key caps are fragile and difficult to remove intact. If you have keyboard problems with an Apple laptop made in 2016 or 2017, you may qualify for the Keyboard Service Program.
    • Key caps are held on by tiny fragile clips. Be careful as you pry up any keys.
  6. Laptop Keyboard Cleaning Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Laptop Keyboard Cleaning Guide: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the key is removed, use compressed air to blow away any debris around the key retainer.
    • To remove any grime buildup around the key retainer, wet a q-tip or a cotton swab with isopropyl alcohol and wipe the area.
    • If the key retainer is sticky, remove it and soak it in hot, soapy water for 5 minutes, then let it dry and replace it.
    • Note the orientation of the key retainer before you remove it!
  7. Laptop Keyboard Cleaning Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To reinstall key caps, take note of where the clips are on the underside, then align the key with the key retainer and apply pressure with your finger to snap the clips back into place.
    • Be gentle as you reapply key caps—the clips that hold them in place are very fragile. If the cap doesn't snap back into place easily, don't force it. Check the alignment of the clips and try again.
    Can one use a toothbrush to clean the keys in the absence of a cotton swabs?
    comcreativ4d - crwdns2934203:0crwdne2934203:0
Congratulations, your keyboard is clean! Repeat these steps every once in a while as needed to keep your keyboard squeaky clean and extend the life of your laptop.
crwdns2935229:037crwdne2935229:0
Taylor Dixon
crwdns2935283:006/26/18crwdne2935283:0
70,500 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Bonjour, est ce possible d’enlever une touche facilement sur MacBook Pro 2018?
mickaelchalard63 - crwdns2934203:0crwdne2934203:0
Non ce n'est pas si facile.
Ben Capehart -
Thanks for the advice with the plectrum! It helped me to just lift a key a bit that didn’t react anymore. No it reacts as expected. (MacBook Air 2013)
Aspartic - crwdns2934203:0crwdne2934203:0
If anybody needs more information on how to remove the keycaps. Apple has published the original instructions on there website: https://support.apple.com/manuals/maclap...
Luis Netzband - crwdns2934203:0crwdne2934203:0
Laptop ka battery kaise change Karen
Sheetal Lala - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 47
crwdns2936753:07crwdne2936753:0 270
crwdns2936753:030crwdne2936753:0 1,075
crwdns2942667:0crwdne2942667:0 125,287
