LG-P970 touch screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace your LG-P970 touch screen.
You can buy this part on amazon http://www.amazon.fr/dp/B00CF29W78
remove the back cover
remove the battery
remove the SIM card
remove the µSD card (Memory)
remove 7 screws on the back
with a tool start to open the back frame
and it's now easy to remove the back frame with hand, carefully
remove buttons
locate the back camera
with a tool raise up the led.carefully
with a tool disconnect the back camera
and remove the camera with your fingers.
don't forget to remove the little connector of screen, with a tool, right next to the empty slot of the camera.
It's time to remove carefully the tactile screen.
don't scratch le LCD!!!
the touch panel is glued with double-sided tape. You can remove it with your fingers. carefull with the touch screen connector.
cut new double sided tape (1-2mm width), put it on the are and peel it.
remove the inside protection on the new touch screen.
carefully put the news touch screen on the LG. Take care that the connector goes right through the right hole.
to finish, add all part by reading these instructions in reverse ;-)
and try if it work !
crwdns2935229:019crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
Hi. To take the screws out do I need a phillips? Thanks.
