This guide will show you how to replace the LCD screen on a LG X Power smartphone.
Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
Don't forget to take out SIM/Micro SD Card tray out before this step.
Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
Pull the cameras out to remove them.
Use the flat end of a spudger to disconnect the battery from the motherboard.
Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
Use a spudger and plastic opening tool to carefully pry up the battery.
Carefully peal off the glued vibration motor by using the plastic opening tool.
Using the plastic opening tool, pry off the ear speaker.
Excellent work. I support the right to repair . Thank you.
crwdns2935229:017crwdne2935229:0
crwdns2947412:07crwdne2947412:0
If you are just replacing the screen, this is wrong. This would help if you are replacing with a “screen in frame”
What is the right way for just the screen?
Please add “with frame” in title. Also need to make sure all contacts are present on the frame of the new screen, transfer them over if not.
Is the x power screen the same size ( or same screen altogether) as the x power 3 screen? If not what screen would I be looking for?
Where’s the part where you actually remove the screen and add in the new one?
The last step seems to be prying off the ear speaker.
Could you please fix this guide when you get the chance? I might replace the screen on my LG Power X [K210]. Thanks.
Okay.... and? I got that far. How do I get the screen out?
What is the price of the screen?
