LG WM3050CW Temperature Sensor Replacement
  1. LG WM3050CW Temperature Sensor Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Temperature Sensor Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Temperature Sensor Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Temperature Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Temperature Sensor Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Temperature Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Temperature Sensor Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Temperature Sensor Replacement, Unfasten the control panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unfasten the control panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
  9. LG WM3050CW Temperature Sensor Replacement, Unfasten the detergent dispenser: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  10. LG WM3050CW Temperature Sensor Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
    • Twist the screwdriver to release the clips securing the control panel.
    • Repeat this procedure for the remaining clips along the control panel.
  11. LG WM3050CW Temperature Sensor Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the control panel upward to completely separate it from the chassis.
    • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
    • Remove the control panel.
  12. LG WM3050CW Temperature Sensor Replacement, Open the door: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Open the door: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the front door completely.
  13. LG WM3050CW Temperature Sensor Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG WM3050CW Temperature Sensor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • This procedure will take significant force.
  15. LG WM3050CW Temperature Sensor Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG WM3050CW Temperature Sensor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work your fingers around the boot until its completely separated from the panel.
  17. LG WM3050CW Temperature Sensor Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the filter panel at the bottom left of the front panel.
    • Twist the filter panel upward to unclip it from the front panel.
  18. LG WM3050CW Temperature Sensor Replacement, Unfasten the filter trim: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 12.8 mm‑long screws securing the filter trim.
  19. LG WM3050CW Temperature Sensor Replacement, Remove the filter trim: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the filter trim: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the filter trim straight off the front panel to remove it.
  20. LG WM3050CW Temperature Sensor Replacement, Unfasten the lower front panel: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the 12.8 mm-long screw securing the lower front panel.
  21. LG WM3050CW Temperature Sensor Replacement, Unfasten the door latch: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
  22. LG WM3050CW Temperature Sensor Replacement, Remove the door latch: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the door latch: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the door latch: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  23. LG WM3050CW Temperature Sensor Replacement, Unfasten the front panel: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unfasten the front panel: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Unfasten the front panel: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Use a Phillips driver, or a 7 mm nut driver, to remove the six 15 mm‑long screws securing the front panel.
  24. LG WM3050CW Temperature Sensor Replacement, Remove the front panel: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the front panel: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the front panel: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  25. LG WM3050CW Temperature Sensor Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front panel.
  26. LG WM3050CW Temperature Sensor Replacement, Disconnect the temperature sensor: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Disconnect the temperature sensor: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the temperature sensor connector downward to disconnect it.
  27. LG WM3050CW Temperature Sensor Replacement, Cut the cable tie: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Cut the cable tie: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use angle cutters, or scissors, to cut the cable ties attaching the temperature sensor to the chassis.
  28. LG WM3050CW Temperature Sensor Replacement, Remove the temperature sensor: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the temperature sensor: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Temperature Sensor Replacement, Remove the temperature sensor: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the temperature sensor straight out of its slot in the chassis to remove it.
    • You may accidentally remove the rubber boot. Don't worry—just reinsert it with the temperature sensor during reassembly.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.786 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.514crwdne2935297:0
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 796
