LG WM3050CW Pump Hose Replacement
  1. LG WM3050CW Pump Hose Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Pump Hose Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Pump Hose Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Pump Hose Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Pump Hose Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the detergent drawer: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG WM3050CW Pump Hose Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG WM3050CW Pump Hose Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the control panel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG WM3050CW Pump Hose Replacement, Unfasten the control panel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the control panel: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the 16.4 mm-long screw securing the control panel.
  9. LG WM3050CW Pump Hose Replacement, Unfasten the detergent dispenser: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 26.3 mm‑long screws securing the detergent dispenser.
  10. LG WM3050CW Pump Hose Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unclip the control panel: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a flathead screwdriver between the chassis and the top left corner of the control panel.
    • Twist the screwdriver to release the clips securing the control panel.
    • Repeat this procedure for the remaining clips along the control panel.
  11. LG WM3050CW Pump Hose Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the control panel: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the control panel upward to completely separate it from the chassis.
    • Pull the control panel away from the chassis, making sure to thread the cables through its slot in the chassis.
    • Remove the control panel.
  12. LG WM3050CW Pump Hose Replacement, Open the door: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Open the door: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the front door completely.
  13. LG WM3050CW Pump Hose Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the boot ring: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG WM3050CW Pump Hose Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • This procedure will take significant force.
  15. LG WM3050CW Pump Hose Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the boot: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG WM3050CW Pump Hose Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work your fingers around the boot until its completely separated from the panel.
  17. LG WM3050CW Pump Hose Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the filter panel: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the filter panel at the bottom left of the front panel.
    • Twist the filter panel upward to unclip it from the front panel.
  18. LG WM3050CW Pump Hose Replacement, Unfasten the filter trim: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 12.8 mm‑long screws securing the filter trim.
  19. LG WM3050CW Pump Hose Replacement, Remove the filter trim: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the filter trim: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the filter trim straight off the front panel to remove it.
  20. LG WM3050CW Pump Hose Replacement, Unfasten the lower front panel: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the 12.8 mm-long screw securing the lower front panel.
  21. LG WM3050CW Pump Hose Replacement, Unfasten the door latch: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
  22. LG WM3050CW Pump Hose Replacement, Remove the door latch: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the door latch: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the door latch: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  23. LG WM3050CW Pump Hose Replacement, Unfasten the front panel: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the front panel: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the front panel: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Use a Phillips driver, or a 7 mm nut driver, to remove the six 15 mm‑long screws securing the front panel.
  24. LG WM3050CW Pump Hose Replacement, Remove the front panel: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the front panel: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the front panel: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  25. LG WM3050CW Pump Hose Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front panel.
  26. LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the tub to pump hose: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
    • Pull the hose straight off the assembly to disconnect it.
  27. LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Unfasten the rear panel: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the four 10.7 mm‑long screws securing the rear panel.
  28. LG WM3050CW Pump Hose Replacement, Remove the rear panel: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the rear panel: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the rear panel: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the rear panel upward to release its bottom clips.
    • Pull the rear panel away from the chassis to release the remaining clips.
  29. LG WM3050CW Pump Hose Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear panel.
  30. LG WM3050CW Pump Hose Replacement, Disconnect the air dome: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the air dome: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the air dome hose straight up to disconnect it.
  31. LG WM3050CW Pump Hose Replacement, Unfasten the air dome: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 16.5 mm‑long screws securing the air dome.
  32. LG WM3050CW Pump Hose Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
  33. LG WM3050CW Pump Hose Replacement, Remove the air dome: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the air dome: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Remove the air dome: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the air dome straight off its hose to remove it.
    • During reassembly, make sure the air dome nub is aligned properly with its slot in the hose.
  34. LG WM3050CW Pump Hose Replacement, Loosen the pump hose: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Loosen the pump hose: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
  35. LG WM3050CW Pump Hose Replacement, Disconnect the pump hose: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Pump Hose Replacement, Disconnect the pump hose: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the pump hose straight off the drum to disconnect it.
  36. LG WM3050CW Pump Hose Replacement, Remove the pump hose: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the pump hose.
    • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,810 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,725crwdne2935297:0
crwdns2942667:0crwdne2942667:0 204
