LG WM3050CW Main Board Replacement
  1. LG WM3050CW Main Board Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Main Board Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. LG WM3050CW Main Board Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. LG WM3050CW Main Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG WM3050CW Main Board Replacement, Disconnect the pressure sensor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement, Disconnect the pressure sensor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the spade connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG WM3050CW Main Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the hose from the pressure sensor.
  7. LG WM3050CW Main Board Replacement, Unfasten the pressure sensor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the 16.5 mm-long screw securing the pressure sensor.
  8. LG WM3050CW Main Board Replacement, Remove the pressure sensor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the pressure sensor: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the pressure sensor: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the pressure sensor toward the left edge of the washing machine to unclip it from the main board cover.
  9. LG WM3050CW Main Board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the pressure sensor away from its slot on the main board cover to remove it.
    • During reassembly, align the pressure sensor with the hole next to its slot before rotating it back into its original position.
  10. LG WM3050CW Main Board Replacement, Unclip the control panel cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Unclip the control panel cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Unclip the control panel cable: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
    • Compress the clip and slide it out of the chassis to remove it.
  11. LG WM3050CW Main Board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use diagonal cutters, or scissors, to cut the cable tie securing the control panel cable to the main board cover.
    • Remove the pressure sensor hose from its clip in the main board cover.
    • During reassembly, replace the cable tie.
  12. LG WM3050CW Main Board Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the twist tie bundling the cables at the top right of the main board cover.
  13. LG WM3050CW Main Board Replacement, Remove the main board cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the main board cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the main board cover: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to disconnect the three plastic clips securing the top of the main board cover.
    • Pull the main board cover away from the chassis to disconnect the remaining clips on the side and bottom.
    • Remove the main board cover.
  14. LG WM3050CW Main Board Replacement, Unfasten the main board: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Main Board Replacement, Unfasten the main board: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the 16.5 mm-long screw securing the main board to the back of the washer.
  15. LG WM3050CW Main Board Replacement, Separate the main board from the chassis: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Separate the main board from the chassis: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Separate the main board from the chassis: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the main board toward the right edge of the device to disconnect the clips from their slots in the chassis.
    • Pull the main board toward the front of the device to completely separate the main board from the chassis.
  16. LG WM3050CW Main Board Replacement, Remove the main board: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the main board: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Main Board Replacement, Remove the main board: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
    • Lift the main board out of the chassis slightly to access each of the connectors.
    • Disconnect each connector from the main board (eleven total).
    • Remove the main board.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37 786 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 514crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2942667:0crwdne2942667:0 455
