LG WM3050CW Door Latch Replacement
  1. LG WM3050CW Door Latch Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Door Latch Replacement, Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG WM3050CW Door Latch Replacement, Open the door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Door Latch Replacement, Open the door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the front door completely.
  3. LG WM3050CW Door Latch Replacement, Remove the boot ring: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement, Remove the boot ring: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement, Remove the boot ring: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  4. LG WM3050CW Door Latch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  5. LG WM3050CW Door Latch Replacement, Disconnect the boot: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement, Disconnect the boot: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement, Disconnect the boot: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the boot off its lip in the front panel.
  6. LG WM3050CW Door Latch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Work your fingers around the boot's perimeter until its completely separated from the panel.
  7. LG WM3050CW Door Latch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Door Latch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to fold the boot into the drum.
  8. LG WM3050CW Door Latch Replacement, Unfasten the door latch: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips driver to remove the two 16 mm‑long screws securing the door latch.
  9. LG WM3050CW Door Latch Replacement, Expose the door latch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement, Expose the door latch: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG WM3050CW Door Latch Replacement, Expose the door latch: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reach between the boot and the chassis to grip the door latch.
    • Pull the door latch toward the back of the device to remove it from its slot in the chassis.
    • Pull the latch towards the left edge of the device to completely expose it.
    • Don't try to fully remove the door latch yet. It's still connected to its wiring harness.
  10. LG WM3050CW Door Latch Replacement, Remove the door latch: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG WM3050CW Door Latch Replacement, Remove the door latch: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the harness connector on the door latch.
    • Always grip cables by their connectors and not the wires themselves.
    • Remove the door latch.
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37 786 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 564crwdne2935297:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 463
