LG V20 Display Replacement
    1. LG V20 Display Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG V20 Display Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG V20 Display Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
      • Remove the back cover.
    1. LG V20 Display Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG V20 Display Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG V20 Display Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
      • Be careful not to deform or puncture the battery.
      • Pry up and remove the battery.
    1. LG V20 Display Replacement, Midframe Assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
    2. LG V20 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
      • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
    3. LG V20 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the phone and insert an opening pick in the gap you created.
      • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
    4. LG V20 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the frame section.
      • Repeat this procedure with the frame section on the other end of the phone.
      • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
    5. LG V20 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
    6. LG V20 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The cover of the motherboard is held in its place by several plastic clamps.
      • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
    7. LG V20 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
    8. LG V20 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the motherboard cover.
    1. LG V20 Display Replacement, Front-Facing Camera: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement, Front-Facing Camera: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to disconnect the front camera flex cable.
      • If you want to go on and remove the motherboard assembly, there is no need to remove the front facing camera after disconnecting it. However if you feel uncertain, carefully remove it with a pair of tweezers.
      • Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
    1. LG V20 Display Replacement, Motherboard Assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
      • The second rear camera will come out with the motherboard since it is connected on the other side.
      • You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
    2. LG V20 Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the display flex cable with the flat end of a spudger.
    3. LG V20 Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the pointed end of a spudger to lift up the motherboard assembly until you can get a good grip.
      • Carefully lift up the motherboard assembly and remove it.
    1. LG V20 Display Replacement, Display: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement, Display: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a pair of tweezers to gently peel off the cable of the secondary screen at the top of your phone.
    2. LG V20 Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use an iOpener to loosen the adhesive on all sides of the display.
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the phone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    3. LG V20 Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that.
      • Use a suction cup to lift the upper end of the display until you can insert the tip of an opening pick.
      • Only insert the tip of the opening to not damage any components beneath the display.
      • Slide the opening pick around all sides of the phone to cut the adhesive.
      • Leave an opening pick in each corner of the phone to prevent the adhesive from resealing.
      • Don't lift up the display straight away after you cut the adhesive on all sides. The two display cables are still threaded through the mid frame of the phone.
    4. LG V20 Display Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG V20 Display Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently thread the main display cable through the gap in the mid frame at the bottom end of your phone. Only lift the lower part of the display to do so.
      • Gently thread the second display cable through the gap in the mid frame at the top of your phone.
    5. LG V20 Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the display.
      • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display and touchscreen cable through the frame. Align the screen and press it into place.
crwdns2935229:020crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
264,661 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2935297:086,241crwdne2935297:0
Need help: My screen came out so I took the phone apart and re-glued the screen with some 1mm 3M tape. Now I reassembled it and it vibrates on boot and I can see the backlight go on because a corner of the screen is broken off… Also WhatsApp Web works. So the phone is definitely working, but the display isnt showing anything… I re-checked the main screen connector at the bottom and it is properly plugged… what can I do?
Raphael Nollau (R4PHikari) - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Your replacement screen might be bad, or your display cable broke in which case you would need a new motherboard.
Brandon Godsey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello,
The secondary screen cable was cut off during the disassembly. Is there any way to fix it or would it be necessary to buy a whole new screen for this purpose?
Thanks.
temp trend - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 92
crwdns2942667:0crwdne2942667:0 20,105
