LG Tribute Touchscreen Replacement
  1. LG Tribute Touchscreen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute Touchscreen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Touchscreen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Touchscreen Replacement, Mid-panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute Touchscreen Replacement, Mid-panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Touchscreen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Tribute Touchscreen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Touchscreen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  6. LG Tribute Touchscreen Replacement, Touchscreen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Tribute Touchscreen Replacement, Touchscreen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Tribute Touchscreen Replacement, Touchscreen: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
crwdns2935229:012crwdne2935229:0
Aaron Amdall
crwdns2935283:001/25/16crwdne2935283:0
940 crwdns2915208:0crwdne2915208:0
University of Wisconsin Stout, Team 1-1, Schneider-Bateman Spring 2016 crwdns2935289:0University of Wisconsin Stout, Team 1-1, Schneider-Bateman Spring 2016crwdne2935289:0
UWSTOUT-SCHNEIDER-BATEMAN-S16S1G1
thank you for all ypu work at web site
salah dholman - crwdns2934203:0crwdne2934203:0
Can you peel away lens without taking apart ?
mikeknapik1 - crwdns2934203:0crwdne2934203:0
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - crwdns2934203:0crwdne2934203:0
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 16,259
