LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement
  1. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Unfasten the condenser cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 14.5 mm‑long screws securing the condenser cover to the rear of the refrigerator.
  3. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Remove the condenser cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Remove the condenser cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Remove the condenser cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the top edge of the condenser cover toward you.
    • Lift and remove the condenser cover.
  4. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the water inlet valve assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the water inlet valve assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the water inlet valve assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze and pull down the yellow and white connectors to disconnect them.
  5. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Reposition the water inlet valve assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the water inlet valve assembly.
  6. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the water inlet valve assembly out of the refrigerator for better access to electrical connections and water tubing connections.
    • Don't try to remove the inlet valve assembly completely because it is still attached by tubes and wires.
  7. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the remaining electrical connection: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the remaining electrical connection: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze and pull downward the remaining water inlet valve assembly connector to disconnect it.
  8. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the water tubing connections: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Disconnect the water tubing connections: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use long nose pliers to pull and remove the locking clip from the smaller white tubing connector.
  9. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to squeeze the flange surrounding the small white water tube toward the valve to release the tube.
    • While you squeeze the flange, pull the tubing straight out of the connector.
  10. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Remove the inlet valve assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Remove the inlet valve assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Remove the inlet valve assembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat this procedure for the remaining tubes.
    • Remove the inlet valve assembly.
  11. LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Test the inlet valve assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Test the inlet valve assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator Model LFX25973 Water Inlet Valve Assembly Test and Replacement, Test the inlet valve assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have a multimeter, you can use it to test the inlet valve assembly components.
    • Set the multimeter to the ohm (Ω) setting.
    • For the first solenoid, test the resistance between the red and blue wires on the white connector.
    • The acceptable resistance is 360 to 420 Ω.
    • Repeat the test on the yellow connector for the other solenoid.
    • To test the flow meter, test the resistance between the red and black wires on the white connector.
    • The acceptable resistance is 4 kΩ to 30 kΩ.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,810 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,725crwdne2935297:0
crwdns2942667:0crwdne2942667:0 262
