LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement
  1. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser Fan Motor
    • Compressor Motor and Thermal Overload Device
    • Water Supply Valve Assembly
  2. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Loosen the left door handle set screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Loosen the left door handle set screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To remove the left door handle, first open the right door.
    • Use a 2 1/2 mm hex wrench to loosen the set screws in the top and bottom of the left door handle.
  3. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the left door handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the left door handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the left door handle straight off to remove it.
  4. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Retaining clip locations: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Retaining clip locations: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Retaining clip locations: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The dispenser assembly is secured by very strong clips, making it very difficult to remove. Take note of the clip locations shown in the photos:
    • Right side clips
    • Top clips
    • Left side clips (Note, the dispenser is being held upside down for the photo, so the upper left side clips are at the bottom of the photo.)
    • During disassembly, you may break some of these clips. If you do, don't worry; the assembly does not need all the clips to be properly secured.
  5. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Release the dispenser: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Release the dispenser: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Release the dispenser: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry out the top edge of the dispenser assembly.
    • Once you've created a gap, use your fingertips to pull the edge downward.
    • Use additional spudgers to unfasten the clips securing the dispenser assembly to the refrigerator door.
    • Optionally, you may use a flat-blade screwdriver to assist in this process. Be careful not to damage the door; you may scratch the door surface or dent the rim of the dispenser opening.
  6. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Reposition the dispenser: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Reposition the dispenser: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Reposition the dispenser: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the top edge of the dispenser assembly in the middle and pull outwards.
    • Continue prying and pulling around the perimeter of the assembly to release it.
  7. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the assembly firmly and pull it out of the refrigerator door.
    • Don't try to pull the assembly completely off the refrigerator door. The assembly is still connected with numerous wires. These are mainly connected to the left side of the dispenser.
  8. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Disconnect the dispenser: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the two multiple wire connectors and pull them straight off to disconnect them from the display board.
    • Do not attempt to remove the four-wire connector from the board as it is not removable.
  9. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze and separate the two-wire harness connector and the four-wire harness connector.
  10. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Unfasten the circuit board holder: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the 11 mm‑long screw securing the white circuit board holder to the dispenser assembly.
    • Lift and remove the circuit board holder from the dispenser assembly.
  11. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the dispenser: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now remove the dispenser from the refrigerator.
    • The white circuit board holder can be suspended from the harness wires, as its weight is minimal.
  12. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the water dispensing switch bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 12.8 mm‑long screws securing the clear switch bracket to the dispenser assembly.
  13. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the switch bracket: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the switch bracket: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the clear switch bracket off the dispenser assembly.
  14. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the water dispensing switch from the bracket: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Remove the water dispensing switch from the bracket: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the water dispensing switch off of its pegs on the bracket.
  15. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Disconnect the water dispensing switch: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Disconnect the water dispensing switch: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the yellow and pink connector straight off the water dispensing switch to disconnect it.
  16. LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Refrigerator LFX25973 Water Dispensing Switch Testing and Replacement, Test the water dispensing switch: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have a multimeter, you can test to see if your water dispensing switch is good or not. Set your multimeter to the continuity function, with beeper.
    • Touch one probe to each of the switch terminals at the same time.
    • When you operate the small lever on the switch the meter should sound.
    • When you release the small lever on the switch the meter should not sound.
    • If the switch does not operate as described above, replace it.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37.518 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.038crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 53
